Wireless AP Equivalent
  • 1.  Wireless AP Equivalent
    Posted Feb 22, 2024 09:25 AM
    Hey Everyone.
    is there a way that i can get aruba equivalents of the below devices:
    Rukus R350, H350, T350
    Any assistance would be greatly appreciated
  • 2.  RE: Wireless AP Equivalent
    MVP EXPERT
    Posted Feb 22, 2024 09:35 AM
    The Rukus R350 is a Wi-Fi generation 6 access point (IEEE 802.11ax) and has 2x2:2 MU-MIMO.
    Equivalents can be the Aruba AP-505 802.11ax 2x2:2 SU-MIMO.
    or go for the newer Wifi 6E with 6GHz capabilities.
    Aruba AP-615 WiFi-6E Tri-band 2x2:2 two radios
    Aruba AP-635 WiFi-6E Tri-band 2x2:2 three radios
    If you look for a outdoor AP check the AP-565
    Ask your local Aruba partner for help with your design.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: Wireless AP Equivalent
    Posted Feb 22, 2024 09:37 AM
    These look like entry level WiFi-6 APs, where the AP503(indoor)/AP503H(hospitality/wallmount)/AP565(outdoor) looks most similar.
    But instead of asking equivalents, it may be better to work with your Aruba partner to design an optimal solution and select the right for your situation.
