Wireless Best Practice / signal strength
  • 1.  Wireless Best Practice / signal strength
    Posted Mar 07, 2013 01:53 AM
     Hi ,
    I would like to know what is the wirless best practice while using Aruba like cisco says -67 DBM signal strength is considered as their best practice...so do we have any document which states about Aruba best practice in terms of signal level.
  • 2.  RE: Wireless Best Practice / signal strength
    Posted Mar 07, 2013 05:39 AM
    -67 in practice is a good target across the board for all clients.  For more information, pleasesee "Optimizing Aruba WLANs for Roaming Devices" here:  http://www.arubanetworks.com/wp-content/uploads/DG_Roaming.pdf
  • 3.  RE: Wireless Best Practice / signal strength
    Posted Mar 18, 2013 10:13 PM
    Hi Joseph,
    Thanks for the document, I have gne through with the document but it says that its -67 dbm for vioce.......in my setup there is no voice only data.
    So any document for best practice for data part ?
  • 4.  RE: Wireless Best Practice / signal strength
    Posted Mar 19, 2013 07:10 AM
    @Bhrt1266 wrote:
    Hi Joseph,
    Bhrt,
    That document accounts for the fact that you might have voice mixed into your population.   The indoor 802.11n site survey and planning document has good information and principles about the network you are interested in building: http://www.arubanetworks.com/wp-content/uploads/Indoor80211n_2012-05-31.pdf
    The -67 number depends on the voice handset manufacturer.  If you are not doing voice, the document above should suffice.
  • 5.  RE: Wireless Best Practice / signal strength
    Posted May 06, 2018 11:43 AM
    I was in site survey today and i was receiving signal strength on my mobile phone -93 dbm beside aruba 205 ap in instant mode and signal strength -80 dbm when moving away from the ap.
    Is it logic?
  • 6.  RE: Wireless Best Practice / signal strength
    Posted May 06, 2018 11:55 AM
    I would use Aruba utilities in the Android Store here to detemine signal strength.  In your screenshot, it could be the 4g signal strength, not the wifi strength...
    https://play.google.com/store/apps/details?id=com.arubanetworks.arubautilities
