last person joined: 7 hours ago
Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
  • 1.  Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
    Posted Jan 30, 2014 02:00 PM
    Hi I have a Aruba IAP-105 deployment and I have to determine best practises to report daily issues, weekly, monthly, quarterly and yearly issues/reports
    what should I be reporting?
  • 2.  RE: Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
    Posted Jan 31, 2014 04:37 AM
    Do you have airwave server? If yes there are some useful reports for your reference.
  • 3.  RE: Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
    Posted Jan 31, 2014 09:40 AM
    If no Airwave, maybe send out syslogs and/or SNMP Traps to another NMS to which you can run reports against.
    You would have to analyze those unfortunately.
    Your best bet is Airwave and/or Central.
  • 4.  RE: Wireless Best Practises for Weekly/Monthly/Yearly Checks on IAP-105 deployment
    Posted Jan 31, 2014 02:09 PM
    Just take note if you want comprehensive reports then get AIrewave else Ceentral will give you "simple" reports such as
    Network Summary
    Security Summary
    PCI Compliance Summary
