Wireless Bridge
  • 1.  Wireless Bridge
    Posted Feb 13, 2020 05:06 PM
    We have a client that is using clear pass with 7230 controller. The client is trying to use IOGEAR GWU637 wireless bridge. The device does not support enterprise authentication. Does anyone know of a device like the IOGEAR that works with enterprise networks or has a better idea on how to accomplish the clients needs?
  • 2.  RE: Wireless Bridge
  • 3.  RE: Wireless Bridge
    Posted Feb 14, 2020 09:24 AM
    Thank you for the reply. I did not know that existed. We are trying to keep it under a 100 dollars.
  • 4.  RE: Wireless Bridge
    Posted Feb 14, 2020 09:26 AM
    802.1x client connectivity and under 100 might be mutually exclusive.
  • 5.  RE: Wireless Bridge
    Posted Jan 19, 2021 12:06 PM
    Hey I am encountering similar issues. I am wondering if you found an adequate solution for around the $100 amount?
    - Abraham
