Wireless control to wired Aruba 4604
  • 1.  Wireless control to wired Aruba 4604
    Posted Jan 13, 2012 04:27 AM
    Hello
    Is it possible to use Aruba controller for authentication wired users via captive portal ? For example :
    I have some group of PC`s connected by Cisco switch and I want users could authenticate via captive portal on Aruba Os.
  • 2.  RE: Wireless control to wired Aruba 4604
    Posted Jan 13, 2012 06:56 AM
    Yes.  You can make that physical port "untrusted".
  • 3.  RE: Wireless control to wired Aruba 4604
    Posted Jan 13, 2012 09:09 AM
    Once that is complete, set the appropriate aaa profile to the "Wired Access" section of the config.
  • 4.  RE: Wireless control to wired Aruba 4604
    Posted Jan 13, 2012 01:47 PM
    Ok, thanks
    another question is, can I use captive portal to assign user to different vlan ( other than before authentication ) depending on answer from radius nevertheless client is wired or wireless.
    I know that cp is layer 3, but is it possible to combine
  • 5.  RE: Wireless control to wired Aruba 4604
    Posted Jan 16, 2012 12:49 PM
    though ArubaOS supports VLAN derviation
    it does not work - for captive portal (has never worked)
