Wireless controller with AP-315
  • 1.  Wireless controller with AP-315
    Posted Mar 19, 2018 03:07 PM
    Hi All,
    I configured controller with dhcp pool inside with out option 43 because controller and AP’s in same Vlan management vlan , when i connect the new AP in switch it will take ip from DHCP pool inside the controller after this it will go to standalone mode until I connect to the AP and manually converted to the controller. How to make the rest AP’s join controller automatically.
    Please help me this is critical situation
  • 2.  RE: Wireless controller with AP-315
    Posted Mar 20, 2018 10:45 PM
    Sounds like you purchased Instant AP-315. If you did, then the APs will come up in instant mode after getting an IP address. Best way would to be bring up all the APs in IAP mode and have them be part of a cluster, then convert them all at once. Otherwise, you have to do it one at a time.
