Higher Education
last person joined: 27 days ago
Got questions on how to enable mobility in education? Submit them here!
Wireless Design
  • 1.  Wireless Design
    Posted Aug 19, 2013 09:32 AM
    Hello
    In two weeks we will deploy wireless in our Puerto Rico Campus. We orderd a 3400 controller for that site and 40 AP-135. The site will VPN back to headqueaters in South Florida, so my question is would you recommend adding the controller in PR as local or master? What are the disadvantage or advantages? For easy managment i can add it as a local so i can push config from the master in main campus, instead of having two master.
    Thank you,
    Nils.
    #3400
  • 2.  RE: Wireless Design
    MVP
    Posted Aug 19, 2013 09:43 AM
    Nils,
    If you have the configuration basically the same at both campuses, making the PR controller a local will definitely centralize configuration changes.
    If there are major changes between campuses, making the PR controller a master might be the preferred option.
  • 3.  RE: Wireless Design
    Posted Aug 19, 2013 09:45 AM
    Local.
    Only disadvantage I see is that the PR location would be dependent on HQ for configuration changes and would also have to be upgraded at the same time as HQ. If you have Airwave though, you can easily manage multiple master controllers and keep configuration profiles in sync between the two.
  • 4.  RE: Wireless Design
    Posted Aug 19, 2013 10:52 AM
    Thank you for the quick reply. My first option will be local because the students in Puerto Rico will use the same SSID and authentication methods so the configuration will be the same.
    Thank you
    Nils
