If I'm correct, the supplicant configuration is a computer config, not a user config, so you could try to apply it to somewhere in the tree where your computer objects are.
Your local AD administrator probably knows better how/where to apply GPOs, I only have experience in lab with simple AD topologies.
Original Message:
Sent: May 14, 2024 03:57 PM
Subject: Wireless Group Policy (GPO) deployment.
I would appreciate if you could help me with the following.
I am deploying the ClearPass solution and I have a detail that the users that connect to the wireless network, I have to manually change the security settings of the interface so that it can authenticate against the ClearPass the Active Directory user and not with the computer name.
The detail is that I want to deploy a Group policy in which all machines in the domain by default authenticate with 802.1x users and computers.
Can someone give me a hand because I link the GPO to the organizational unit where the AD users are but the policy does not apply and I have to change these network settings on the computer of each user.
