WIreless IAP 365 not showing speed constantly.
  • 1.  WIreless IAP 365 not showing speed constantly.
    Posted Aug 09, 2019 08:28 AM
    We have a proper internet bandwidth. A wired laptop showing speed is approx 100Mbps constantly. But HPE Aruba 365 access point is showing less.(Not constantly)
    (Morning time - 90Mbps, Day time - 2Mbps
    HPE aruba controller 7240xm, Airwave AMP 8.2.6, and Brocade VDX 6740 switch are working fine.
    Find attached screenshot of the speed test have done multiple times in a day with same SSID and same network.
    Could you please help us to fix the issue?
  • 2.  RE: WIreless IAP 365 not showing speed constantly.
    Posted Aug 09, 2019 09:17 AM
    What client, what band, is the client the only client on the AP, what environment is the AP on and what surounding APs are interfering?
  • 3.  RE: WIreless IAP 365 not showing speed constantly.
    Posted Aug 13, 2019 08:03 AM
    1. Yes, the only one client is connected on the IAP.
    2. Band is - 2.4Ghz & 5.0 GHz
    3. Yes, there is one more AP (IAP 105) installed in the premises.
    Same is submitted for kind perusal.
