I'm new to Aruba and trying to figure out how to create a P2P mesh between a 365 (Portal role) and a 367 (Point role) inside Central. I have turned off Extended SSID on the VC and enabled LAN Bridging on the 367. The 367 doesn't even connect to the 365 over Wifi.
They are running the latest firmware (8.3.0.1_65474) and the 365 has the Mesh role of Portal.
What else do I need to change on this?
I've searched heaps online and according to the articles, this is all I need to do.
