I'm not sure if such data is exposed via SNMP. Most people use tooling like Aruba Central or Airwave. Of there is no IOD in the MIB, it's not exposed via SNMP.
You may have a look at the API or CLI command scraping as an alternative (but don't have an example for you, never done or attempted this).
Original Message:
Sent: Jul 31, 2024 02:02 AM
Subject: Wireless monitoring
I have an Aruba controller and I want to monitor wireless interference. What should I do? I want to get the corresponding indicators through snmp. I downloaded the MIB file, but there is no corresponding OID in the file, so I can't generate the corresponding SNMP file.
