Good day , I hope you are well
Would you give me you advise regarding the below design
Customer have university campus
Class room capacity is 150 user
Class room area 10 m x 8
Application running is interactive learning
There will be live lectures at university at Canada will be viewed here at Egypt classroom
The student will access wireless from their own devices to see the stream
They can ask questions and show presentation also
I think that each user will require from 2 – 4 Mbps data rate to have good connection
I used 3 x AP-205 for each class
Each AP should be loaded with 50 users
Each radio expected to have 25 user
By aruba test-bench analysis ,each user will have from 2 – 4 Mbps
Is that good or we can increase no of AP at each class room to 4
The bad point if larger no of users are 2.4 only as ex
120 user 2.4 & 30 users 5 Ghz
Each AP will have 40 users on 2.4 Radio and 10 users on 5 Ghz Radio
Then users on 2.4 will get lower data rate than users on 5 Ghz
