I am trying to understand how the multipe radios work together and clients communicate simultaneously.
Suppose I have AP-225 which supports a/b/g/n/ac. It is 3x3 MIMO and 3 antennas each for both 2.4 and 5 GHz. Now I am trying to understand the following:
- Does it have 3 antennas each for 2.4 Ghz and 5 Ghz and each has transmit & receive capability?
- If a client connect on g 2.4Ghz , does it connect to one antenna? Can another user connect to same antenna with timeshare? Or, does all three antenna work together to handle all 2.4 Ghz clients simultaneously? How does timeshare work.
- If a client connect on ac 5 Ghz to the same AP, does the 5 Ghz radio work separately from 2.4 Ghz and does not wait for free time ?
- If another 5 Ghz n client connect to this ap can it work together with the first client since it has MIMO technology?
- How does channel bonding work in this case?
#AP225
