Wireless roaming with handheld using WPA2 vs WPA3
  • 1.  Wireless roaming with handheld using WPA2 vs WPA3
    Posted Jan 24, 2023 04:56 AM
    Hello community,
    Recently, I was at a customer's site for roaming problems with Zebra handheld scanners on a separate SSID. Despite having adequate signal coverage and overlap, the wireless connection was interrupted each time when walking through the organization and moving between AP's.
    I tuned several settings like; signalstrength, power settings, channels etc, but I could nog get the roaming to become smoothly. Only when I was walking very slow then there were no disconnects!
    Eventually I was able to solve the problem by changing the security of the SSID from WPA3 to WPA2. After that, roaming was no longer a problem and the disconnects were gone.
    I know WPA3 is an improvement of WPA2 and is more secure, but has anyone seen similar problems?
  • 2.  RE: Wireless roaming with handheld using WPA2 vs WPA3
    Posted Jan 24, 2023 05:20 AM
    WPA3 is very new and has not been tested as rigorously as WPA2.  In something like a Zebra scanner that does not get updates as often I would stick to WPA2.  With that said, I would contact Zebra and see if they have heard of the issue so they can provide guidance and troubleshooting tips.
  • 3.  RE: Wireless roaming with handheld using WPA2 vs WPA3
    Posted Jan 24, 2023 08:43 AM
    Thanks you for your reply!
    We are indeed going to contact Zebra to discuss this issue.
