Wireless Slow after migrating to 802.1x
  • 1.  Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 02:50 PM
    Hello everyone
    We have two SSID: Open (Mac Auth) and A new SSID (802.1x)
    I have dorms students complaning the 802.1x SSID is slow. There is quite a difference when testing with speedtest.net.
    Open: 60 Mbps
    Secure SSID: 6Mbps
    I know it is not a reliable speed test etc. Just poiting out the big difference betwee the two SSIDs.
    So, I wanted to check transfer rate by sending a 20MB file between two computers over wireless. When i transfer the file connected on the Open SSID i obtain a rate of 49Mbps , while on the 802.1x SSID 2.7Mbps.
    Laptop
    RSSI -60db
    802.11n
    Association Rate: 145Mbps
    MCS index: 15
    Channel 153, 5Ghz Band, 20Mhz
    I understand that AES encryption create more overhead, but this is quite a difference. Also, I understand reliable throughput is difficult to estimate. At the moment of the test there were no other clients connected to the AP. So, I have students in the dorm complaning that the Secure SSID is slow.
    - I will open a ticket with TAC.
    Secure SSID:
    show wlan virtual-ap ClearPass_VAP
    Virtual AP profile "ClearPass_VAP"
    Parameter                                       Value
    AAA Profile                                     ClearPass_AAA
    802.11K Profile                                 default
    Hotspot 2.0 Profile                             N/A
    SSID Profile                                    ClearPass_SSID
    Virtual AP enable                               Enabled
    VLAN                                               Pool
    Forward mode                                    tunnel
    Allowed band                                    all
    Band Steering                                   Disabled
    Steering Mode                                   prefer-5ghz
    Dynamic Multicast Optimization (DMO)               Enabled
    Dynamic Multicast Optimization (DMO)               Threshold  6
    Drop Broadcast and Unknown Multicast              Enabled
    Convert Broadcast ARP requests to unicast         Enabled
    Authentication Failure Blacklist Time                     3600 sec
    Deny inter user traffic                                            Disabled
    Deny time range                                 N/A
    DoS Prevention                                  Disabled
    HA Discovery on-association                     Enabled
    Mobile IP                                       Enabled
    Preserve Client VLAN                            Disabled
    Remote-AP Operation                             standard
    Station Blacklisting                            Enabled
    Strict Compliance                               Disabled
    VLAN Mobility                                   Disabled
    FDB Update on Assoc                             Disabled
    WMM Traffic Management Profile                  N/A
    (CS_Local) #show wlan ssid-profile ClearPass_SSID
    SSID Profile "ClearPass_SSID"
    Parameter                                         Value
    SSID enable                                       Enabled
    ESSID                                             ClearPass_Test
    Encryption                                        wpa2-aes
    Enable Management Frame Protection                Disabled
    Require Management Frame Protection               Disabled
    DTIM Interval                                     1 beacon periods
    802.11a Basic Rates                               6 12 24
    802.11a Transmit Rates                            6 9 12 18 24 36 48 54
    802.11g Basic Rates                               1 2
    802.11g Transmit Rates                            1 2 5 6 9 11 12 18 24 36 48 54
    Station Ageout Time                               1000 sec
    Max Transmit Attempts                             8
    RTS Threshold                                     2333 bytes
    Short Preamble                                    Enabled
    Max Associations                                  64
    Wireless Multimedia (WMM)                         Disabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave  Enabled
    WMM TSPEC Min Inactivity Interval                 0 msec
    Override DSCP mappings for WMM clients            Disabled
    DSCP mapping for WMM voice AC                     56
    DSCP mapping for WMM video AC                     40
    DSCP mapping for WMM best-effort AC               24
    DSCP mapping for WMM background AC                8
    Multiple Tx Replay Counters                       Disabled
    Hide SSID                                         Disabled
    Deny_Broadcast Probes                             Disabled
    Local Probe Request Threshold (dB)                0
    Disable Probe Retry                               Enabled
    Battery Boost                                     Disabled
    WEP Key 1                                         N/A
    WEP Key 2                                         N/A
    WEP Key 3                                         N/A
    WEP Key 4                                         N/A
    WEP Transmit Key Index                            1
    WPA Hexkey                                        N/A
    WPA Passphrase                                    N/A
    Maximum Transmit Failures                         0
    EDCA Parameters Station profile                   N/A
    EDCA Parameters AP profile                        N/A
    BC/MC Rate Optimization                           Disabled
    Rate Optimization for delivering EAPOL frames     Enabled
    Strict Spectralink Voice Protocol (SVP)           Disabled
    High-throughput SSID Profile                      default
    802.11g Beacon Rate                               default
    802.11a Beacon Rate                               default
    Video Multicast Rate Optimization                 default
    Advertise QBSS Load IE                            Disabled
    Advertise Location Info                           Disabled
    Advertise AP Name                                 Disabled
    802.11r Profile                                   N/A
    Enforce user vlan for open stations               Disabled
    Enable OKC                                        Enabled
    Any suggestions?
    Thank you
    Nils.
  • 2.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 02:54 PM
    WMM should be enabled.
  • 3.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:12 PM
    Agree I will enable it. Have you encourter similar situation? I am going to test from different area on the campus. Packets are taking the same hops. Also, there is no firewalls. One difference is that the Secure network have a single vlan 4,000 addresses while the Open have a single vlan of 1,000 addresses. Clearpass is the authentication server for the Secure and database for mac auth for the open ssid.
    Thank you for you time,
    Nils.
  • 4.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:17 PM
    You should associate a device to that 802.1x SSID and then give us the output of "show ap association client-mac <mac address of that device>"
  • 5.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:35 PM
    WMM is required in RSN 802.11n+ networks.
  • 6.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:40 PM
    Here is the output;
    (CS_Local) #show ap association client-mac b8:e8:56:10:9c:c2
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name        bssid              mac                auth  assoc  aid  l-int  essid  vlan-id  tunnel-id  phy             assoc. time  num assoc  Flags  Band steer moves (T/S)
    Commons_52  d8:c7:c8:8d:e0:d1  b8:e8:56:10:9c:c2  y     y      2    10     1NSU   717      0x108ae    a-HT-20sgi-2ss  37m:53s      2          WAB    0/0
    b8:e8:56:10:9c:c2-d8:c7:c8:8d:e0:d1 Stats
    Parameter                            Value
    Channel                              153
    Channel Frame Retry Rate(%)          0
    Channel Frame Low Speed Rate(%)      0
    Channel Frame Non Unicast Rate(%)    0
    Channel Frame Fragmentation Rate(%)  0
    Channel Frame Error Rate(%)          0
    Channel Bandwidth Rate(kbps)         0
    Channel Noise                        96
    Client Frame Retry Rate(%)           0
    Client Frame Low Speed Rate(%)       0
    Client Frame Non Unicast Rate(%)     0
    Client Frame Fragmentation Rate(%)   0
    Client Frame Receive Error Rate(%)   0
    Client Bandwidth Rate(kbps)          0
    Client Tx Packets                    315999
    Client Rx Packets                    109613
    Client Tx Bytes                      68690609
    Client Rx Bytes                      95231712
    Client SNR                           29
    A2c_SM SeqNum, Old SeqNums           134 0
  • 7.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:43 PM
    It does not look like an RF issue.  Is the controller the default gateway for clients, or is it a layer 3 switch?
    WMM is automatically enabled when 802.11n is turned on regardless of the SSID parameter...
  • 8.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:49 PM
    The default gateway is terminated on a Layer 3 Switch. Between the controller and the router we have 2 10Gb ports LAG.
  • 9.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:51 PM
    I would move the 802.1x SSID onto the same VLAN as the open SSID or create a new SSID with 802.1x and match the VLAN with the open SSID to see if it makes a difference.
  • 10.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 03:59 PM
    I am suspecting it could be something in the router, But i want to discard wireless controller settings. The Secure SSID DG terminate in a different L3 router than the Open SSID. Also, the Open SSID we provide public addresses and the 802.1x SSID is natted addresses. We provide public  addresses to the Open SSID because is the network student uses for game consoles and streaming devices. In the 802.1x I verified the roles Students and Employees and on Both there is no BW restrictions.
    The Dorms building anchor have only a 1Gb port as uplink. However, I checked and it is not overutilized. Also, let me mention we are on summer break and we dont have the full amont of students until fall. However, it is a concern that without too many students on the dorms the 802.1X SSID will be slow.
    Thank you
    Nils.
  • 11.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 04:01 PM
    Too many variables.  You need to put 802.1x on the open SSID and test.
  • 12.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 16, 2016 04:04 PM
    You are right!! I will try it and report my findings.
  • 13.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 17, 2016 03:02 PM
    So I created an 802.1x SSID for testing
    - Regardless of which vlan the wireless connnection is slow. 7Mpbs Avg.
    Then I created a Open SSID for testing
    - Regardless of which vlan the wireless connection seems to Avg 40 Mbps.
    Still quite a differnce between the secure and open ssid.
    So then I moved the AP from one building to another controller and experience the same issue.
    On Monday i will call support. Any suggestions?
    Thank you
    Nils.
  • 14.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 17, 2016 03:17 PM
    Yes.  Call support.
  • 15.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 17, 2016 06:09 PM
    You said that the controllers are not the gateway, and you suspecting a router might be causing the issue. You could test that by placing two PC's on the switch in the same vlan as the wireless users use and try your tests again. This would bypass the wireless but still use the same infrastructure path up to but before the controllers. Just a thought.
  • 16.  RE: Wireless Slow after migrating to 802.1x
    Posted Jun 27, 2016 10:48 AM
    I found the problem to be not the wireless controllers but a tipping point box between the AP and controller was doing a L3 scanning causing slowness on the encrypted SSID. In case someone else run into a similar issue.
    Thank you
    Nils.
  • 17.  RE: Wireless Slow after migrating to 802.1x
    Thank you
    Nils.
  • 18.  RE: Wireless Slow after migrating to 802.1x
    Yes my next step will be to create a new 802.1X ssid with the same vlan of  the OPEN SSID and test.
