WLAN CONNECTION IRREGULARITIES
  • 1.  WLAN CONNECTION IRREGULARITIES
    Posted Jan 22, 2015 04:52 AM
    I am currently having some connection problems in my WLAN, i therefore debugged client and got the results below, can someone explain what the messages mean, and what the problem is:
    version 5.0.3.0-1.1.0
    virtual-controller-country DE
    virtual-controller-key cff5adbf014426cfb9547bc010dfaad80ea4ee1ce5595390f1
    name Instant-C9:B1:B7
    terminal-access
    rf-band all
    allow-new-aps
    allowed-ap d8:c7:c8:c9:b1:b7
    allowed-ap d8:c7:c8:c9:b1:c7
    allowed-ap d8:c7:c8:c9:38:4f
    allowed-ap d8:c7:c8:c9:b1:a1
    allowed-ap d8:c7:c8:c9:b1:35
    mgmt-user admin e459252c207483972e0aa9b077beb5decc6bc17a857df186
    wlan ssid-profile WLAN1
    index 0
    type employee
    essid WLAN1
    wpa-passphrase b34cd25c5af6d9e461fce99f25671394b117494b299f1b5f
    opmode wpa2-psk-aes
    vlan guest
    rf-band all
    captive-portal disable
    wlan ssid-profile WLAN2
    index 1
    type employee
    essid WLAN2
    wpa-passphrase 270b4a7bdeac1347efa7a5f9a0292ca41ec431be0b87c469
    opmode wpa2-psk-aes
    rf-band all
    enet-vlan guest
    wlan access-rule WLAN1
    index 0
    rule any any match any any any permit
    wlan access-rule WLAN2
    index 1
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
  • 2.  RE: WLAN CONNECTION IRREGULARITIES
    Posted Jan 22, 2015 06:45 AM
    This out put is not enough to identify the issue, can you please explain what type of issues you are facing ?
    1. Connectivity ?
    2. Authentication ?
    3. VLAN and IP address ?
    I found some thing in your out put,
    1. Why are you broadcasting both the SSIDs for employees with the same Authentication (wpa2-psk-aes)
    2. Why WLAN 1 is mapped to Guest VLAN ?
    3. I guess you are trying to broadcast 2 SSIDs  one for Guest and other for Employee right. if so please correc your configuration accordingly.
    index 0
    type employee
    essid WLAN1
    opmode wpa2-psk-aes
    vlan guest
    rf-band all
    index 1
    type employee
    essid WLAN2
    opmode wpa2-psk-aes
    rf-band all
    enet-vlan guest
  • 3.  RE: WLAN CONNECTION IRREGULARITIES
    Posted Jan 22, 2015 08:53 AM
    Thanks very much for your assistance and reply. I found a solution to the current problem. I just factory reset the APs and setup everything from scratch.
  • 4.  RE: WLAN CONNECTION IRREGULARITIES
    Posted Jan 22, 2015 06:50 AM
    You are running very old code. Are you able to upgrade?
    Tim
  • 5.  RE: WLAN CONNECTION IRREGULARITIES
    Posted Jan 22, 2015 06:59 AM
    I tried to update the firmware through the web interface. But it says i have the latest updates.
    Is there some other way to upgrade?
    Sent from Samsung Mobile
