Cloud Managed Networks
WLAN Northbound API is not enabled for customer id
This thread has been viewed 28 times
  • 1.  WLAN Northbound API is not enabled for customer id
    Posted Feb 24, 2021 12:07 PM
    Hi there,
    We are having problems with several Aruba Rest APIs.
    What we are trying to do is to read (and later we will need to write) SSID configurations.
    Several configuration APIs, namely any API in WLAN configuration section (e.g. Get WLAN list of an UI group etc...), returns a strange error :
      "description": "WLAN Northbound API is not enabled for customer id: XXXXXXX.",
      "error_code": "0001",
      "service_name": "Configuration"
    We are pretty stuck here.
    Any help please
    Evgeny Tsirkin
  • 2.  RE: WLAN Northbound API is not enabled for customer id
    Posted Feb 25, 2021 05:15 PM
    I think wlan config api section is changing. Please contact TAC
  • 3.  RE: WLAN Northbound API is not enabled for customer id
    Posted Sep 14, 2021 06:29 PM
    This appears to still be an issue. I can call some APIs but not this one: /configuration/v1/wlan/{group_name_or_guid}/{wlan_name}
    It seems I can't call anything under /configuration/* API is DEFINITELY enabled as I can call anything under the Monitoring node.
    Does this node need special treatment from TAC?
    ACCX #1239 || ACMX #1384 || ACEP || ACSP || CWNA || CWSP
  • 4.  RE: WLAN Northbound API is not enabled for customer id
    Posted Sep 09, 2024 02:02 PM
    Hi zemerick1,
    Did you resolve the issue, I'm getting the same error when trying to modify an existing vlan using
    /configuration/v2/wlan/
    Thanks in advance,
    RObert.
  • 5.  RE: WLAN Northbound API is not enabled for customer id
    Posted Sep 10, 2024 03:34 AM
    Hi.
    You need to request Northbound API to be enabled for your Aruba Central account. It's disabled by default. Open TAC case and ask for it.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
