last person joined: 10 hours ago
WLAN on Aruba Central authentication AD credencials and Palo Alto
  • 1.  WLAN on Aruba Central authentication AD credencials and Palo Alto
    Posted Jan 28, 2021 03:41 PM
    I create WLAN for authenticate with AD credentials, first using Aruba´s Certificate and before Palo Alto´s Certificate.
    But, both don´t are connection.
    My configs:
    On Wlan -> Security:
    Key Management - Dynamic Wep With 802.1.x
    Primary Server: My Server AD-> Server Type (LDAP) and credentials for AD.
    Mobile client the connection is Ok.
    When PC/Laptop try connect, appear for informer credentials (username/password) , but not connect; On Aruba Central appear error: Dot1X stage.
    Regards.
    Alexandre
