WLAN Ping response is more than 1000ms
  • 1.  WLAN Ping response is more than 1000ms
    Posted May 04, 2015 04:23 AM
    When i do ping google.com -t on WLAN, I am getting too much delay repsonse even in 4digits 1000, 1150, 1400, 1600, but not more than 2000ms. When i do ping google.com -t on LAN, I am getting delay not more than 300ms.
    Although my WAN interface for LAN and WLAN is same in both cases.
    what is happening on my WLAN ?
  • 2.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 05:03 AM
    It could be a number of things. You should ping the default gateway to isolate your possible issue from your internet connection.
  • 3.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 10:25 AM
    Through LAN I checked the ping response of VC IP, IAPs IP and VLANs default gateway which is not more than 3ms. google & facebook ping response not more than 300ms.
    Through WLAN  I checked the ping response of VC IP 1800ms, IAPs IP 1150ms, VLANs default gateway ping response 1600ms and google/facebook ping respose more than 1200ms.
    WAN interface is same in both cases. When i do the tracert google.com from LAN I didnt found  any latency on the internet path. VLANs are same on LAN and WLAN.
    What should i do now ?????
    Your valuable support in this regard will be appreciable.
  • 4.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 11:07 AM
    Do you also get a slow response when you ping from the VC using a SSH Telnet session?
  • 5.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 11:10 AM
    Yes from VC as well too much delay.
  • 6.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 11:12 AM
    Does it required to upgrade the AOS ?
    current AOS 6.3.1.8 4.0.0.6
  • 7.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 11:26 AM
    If you are in the VC and are pinging from there, it should match your wired ping times. If it is significantly more you should probably consider opening a TAC case.
    I would also make sure that the physical ports you plug the VC into does not have any errors.
  • 8.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 11:34 AM
    There are 32 accesss points based on virtual controller solution.
    When i connect my laptop to that port where the IAP is connected and checked the ping response wich is not more than 300 sec on google and facebook. Also when i ping the VC-IP, IAPs IP and VLANs default gateway IP i am getting the delay response not more than 3ms.
    When i get connected to the WLAN and ping the default gateway of my vlan  I am getting the delay response too much.
  • 9.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 11:46 AM
    If you SSH into the VC and you don't have a problem pinging wired endpoints your issue could be congestion or contention on your WLAN. How many SSIDs and users do you have? Do you have broadcast filtering on all of your SSIDs?
  • 10.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 12:37 PM
    Yeh broadcast filtering is enabled.
    total 4 SSID with broadcast filtering enabled.
  • 11.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 12:42 PM
    What does your channel utilization look like?
  • 12.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 12:44 PM
    Channel utilization is just 20 to 30 %. Not so much utilization. On each SSID maximum clients are 20 to 30
  • 13.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 12:55 PM
    Your response times are not necessarily bad and your utilization is not bad. Typical applications can adapt to those response times. I would only worry if you were using a delay sensitive application like VoIP.
  • 14.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 12:57 PM
    On my network, I am not using some special application.
    Suppose If I am using some special application on my network, why should it not creating high latency on LAN ?????
  • 15.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 01:00 PM
    What applications are you using on the WLAN?  4 SSIDs  can definitely contribute to your WLAN latency.  The WLAN is a shared medium and users on the WLAN can make things slower for others.  The number of SSIDs you broadcast can also make things slower.  Having access point power above 18 in a dense deployment can also make things slower and case latency.
  • 16.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 01:03 PM
    I am not using any application.
  • 17.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 01:06 PM
    Are your users complaining?
  • 18.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 01:09 PM
    Yes.... Users are complaining slow browsing, disconnectivity sometimes.
    However users on LAN are not complaining.
  • 19.  RE: WLAN Ping response is more than 1000ms
    Posted May 04, 2015 01:44 PM
    LAN bandwidth is not a shared medium like wireless, so your wireless users will always complain first.
    I would start your ARM min at 12 and max at 18, so that your power is not too high.  4 SSIDs is too much and I would consider removing at least one to reduce overhead.  If you still have problems, you should open a case with TAC.
