WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
  • 1.  WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 24, 2014 03:38 PM
    Dear All,
    I was  trying  to register below Controoller and Access point unfortunitly i cannot able to register the Access point in WLC i have tryied to change IOS as per our community disscussion but  i dont know even i cannot able to change IOS
    Kindly please help me for configuring below WLC and Access poing
    Somebody can configuration guide of deployment guide very help for me
    Plzz share with me i am waiting for the reply
    Regards
    Muhammed
  • 2.  RE: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 24, 2014 03:41 PM
    Is it an AP-103 or a W-AP-103?
  • 3.  RE: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 24, 2014 09:12 PM
    thanks for your reply
    AP-103
  • 4.  RE: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 24, 2014 10:54 PM
    You need to use Dell branded APs with Dell branded controllers.
  • 5.  RE: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 25, 2014 05:38 AM
    Hello Everyone, The AP model is W-AP103, kindly let us know the pre-requisites to register the AP's with the Controller.
    Regards
    Azmatullah
  • 6.  RE: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 25, 2014 08:06 AM
    Regards
    Azmatullah
    The datasheet on Dell's website here:  http://i.dell.com/sites/doccontent/shared-content/data-sheets/en/Documents/Dell_Networking_103_Series_Access_Points.pdf says AOS 6.4.0.1
  • 7.  RE: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
    Posted Dec 26, 2014 01:50 AM
    What version of AOS are you running? If you have valid support with Dell then you should be able to get the new code from them.
