WLC not redirecting web traffic to Captive Portal
  • 1.  WLC not redirecting web traffic to Captive Portal
    Posted Mar 13, 2018 12:11 PM
    Community,
    I had this issue resolved back in October of 2017 but for whatever reason I am running into this situation again. I have a WLAN (CDT-Green) that is supposed to redirect user web traffic to a custom captive portal page where they have to hit the "accept" button to get to the internet. I can connect to the WLAN just fine using the password, but when I open a web browser, the WLC (3200XM) is not redirecting the traffic to the captive portal page. The configs are as follows:
    wlan virtual-ap "CDTGreen"
    aaa-profile "CDTGreen_AAA"
    ssid-profile "CDTGreen_SSID"
    no vap-enable
    vlan 1109
    deny-inter-user-traffic
    aaa profile "CDTGreen_AAA" (the initial role here is "logon")
    authentication-dot1x "dot1x_prof-ckz60"
    user-role logon
    captive-portal "default"
    access-list session logon-control
    access-list session captiveportal
    access-list session vpnlogon
    access-list session v6-logon-control
    access-list session captiveportal6
    logon     2    Up: No Limit,Dn: No Limit  logon-control/,captiveportal/,vpnlogon/,v6-logon-control/,captiveportal6/
    aaa authentication captive-portal "default"
    default-role "logon"
    redirect-pause 2
    no user-logon
    guest-logon
    no logout-popup-window
    protocol-http
    login-page "/upload/custom/default/Captive Portal3.htm"
    no enable-welcome-page
    any help you can provide would be fantastic! Thanks!
  • 2.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 13, 2018 12:20 PM
    You have a space in between Captive Portal3
  • 3.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 13, 2018 01:48 PM
    Victor,
    Thank you so much for the reply. I fixed the name of the file to not include a space but unfortunately the WLC is still not redirecting the traffic to the internal Captive Portal. Do you need any other outputs from me?
  • 4.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 13, 2018 02:20 PM
    Do you have an IP address assigned under the guest VLAN ? It is required for the redirect to work
  • 5.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 13, 2018 02:32 PM
    The vlan were using is vlan 1103, the machine gets an IP address and connects to the SSID just fine. It just wont redirect to the captive portal page. Its not in a "guest network" setup eventhough we call it a "Guest" network.
  • 6.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 13, 2018 02:39 PM
    You need to assign an IP under that VLAN (Aruba Controller)
    conf t
    Interface VLAN 1103
    IP address x.x.x.x x.x.x.x
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 7.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 19, 2018 01:33 PM
    Victor,
    Thanks for your help! I figured out the issue was with the vlan the wlan was on. I fixed that and now the portal is redirecting. However, I am having another issue. When the controller redirects the web traffic to the captive portal, after the user hits the "Accept" button the controller doesnt allow the traffic. The initial URL is:
    http://10.129.129.166/upload/custom/default/CaptivePortal3.htm?cmd=login&mac=94:65:9c:46:5f:eb&ip=172.16.20.7&essid=CDT%2DGreen&apname=6c%3Af3%3A7f%3Aca%3Af1%3A29&apgroup=Cedar_WLAN&url=http%3A%2F%2Fwww%2Ewalmart%2Ecom%2F
    But when the "Accept" button is selected, the URL is:
    http://10.129.129.166/upload/custom/default/CaptivePortal3.htm?errmsg=Access%20denied&mac=94:65:9c:46:5f:eb&ip=172.16.20.7&essid=CDT%2DGreen&apname=6c%3Af3%3A7f%3Aca%3Af1%3A29&apgroup=Cedar_WLAN&url=http%3A%2F%2Fwww%2Ewalmart%2Ecom%2F
    Please notice the "errmsg=Access%20denied" statement. Any ideas what to check here?
    Here is more info about the custom captive portal page. This is info about the "Accept" button.
    <b>CLICK ON THE BUTTON BELOW TO ACCEPT THE ABOVE POLICY TERMS.</b></font>
    <br><br><br>
    <form name="form1" method="post" action="/auth/index.html/u">
    <span class="bodytext">
    <input type="hidden" id="email" name="email" type="text" value="user@company.com" class="text" accesskey="e" />
    <input type="hidden" name="cmd" value="authenticate" />
    <input type="submit" name="Login" value="I ACCEPT" class="button" />
    </span>
    </form>
    </div>
    </body>
  • 8.  RE: WLC not redirecting web traffic to Captive Portal
    Posted Mar 19, 2018 04:22 PM
    Victor,
    Please disregard, i found the issue. The "Guest Login" check box was unchecked in the L3 Authentication tab.
