WMS General Learn-System-Wired-Macs Enable Command
  • 1.  WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 03, 2012 02:49 PM
    Hey All,
    Have a possible newb question here - the command "wms general learn-system-wired-macs enable" command is not an option for me.  These are the only options available under the wms command:
    (config) #wms ?
    ap                      configure AP mode
    clean-db                Clean Database
    client                  configure client mode
    export-class            Export classification data to a file
    export-db               Export DB to a file
    import-db               Import DB from a file
    reinit-db               Reinitialize Database
    We have the RFProtect License (with WIP + Spectrum Monitoring) and we're currently running OS version 6.1.3.5.  Any reason why that command isn't available?
    Brian
  • 2.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 03, 2012 07:41 PM
    Please type "show keys" to make sure your licenses were applied.
  • 3.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 04, 2012 09:25 AM
    (FLMWLANCONT001) #show keys
    Licensed Features
    Feature                                             Status
    Access Points                                       32
    Remote Access Points                                32
    Ortronics Access Points                             0
    Outdoor Mesh Access Points                          128
    RF Protect                                          32
    Voice Service Module                                Unlimited
    VPN Server Module                                   2048
    xSec Module                                         0
    Indoor Mesh Access Points                           128
    120abg Upgrade                                      0
    121abg Upgrade                                      0
    124abg Upgrade                                      0
    125abg Upgrade                                      0
    Next Generation Policy Enforcement Firewall Module  32
    Advanced Cryptography                               0
    Service provider AP                                 0
    RF Protect                                          ENABLED
    Policy Enforcement Firewall                         ENABLED
    Remote APs                                          ENABLED
    External Services Interface                         ENABLED
    Client Integrity Module                             ENABLED
    VPN Server                                          ENABLED
    xSec Module                                         DISABLED
    MMC AP                                              DISABLED
    Netgear AP                                          DISABLED
    Voice Services Module                               ENABLED
    Ortronics AP                                        DISABLED
    Mesh Point APs                                      ENABLED
    AP Developers Module                                DISABLED
    Internal Test Functions                             DISABLED
    Public Access                                       DISABLED
    Policy Enforcement Firewall for VPN users           DISABLED
    Content Security                                    DISABLED
    Advanced Cryptography                               DISABLED
    L2/L3 Switching                                     DISABLED
  • 4.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 06, 2012 09:20 AM
    In order to enable this command, you must go into the wms general profile like so:
    (MLIXWC1TOR200) (config) #ids wms-general-profile
    (MLIXWC1TOR200) (IDS WMS General Profile) #learn-system-wired-macs
    This should do it for you.
  • 5.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 06, 2012 09:32 AM
    Pmonardo,
    Thank you!
  • 6.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 06, 2012 10:41 AM
    For once I can answer a question!!!!
  • 7.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted Dec 06, 2012 12:07 PM
    Thanks - that worked!
  • 8.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted May 16, 2018 02:45 PM
    Could you please let me know if enabling this command will allow the controller to classify a Rogue device without the need to trunk client VLAN to the APs/AMs?
  • 9.  RE: WMS General Learn-System-Wired-Macs Enable Command
    Posted May 16, 2018 04:54 PM
    It will collect all of the wired mac addresses from the controller VLANs, yes.  Those mac addresses are propagated to access points so that they can correlate them to things seen on the wireless network.
