Wired Intelligent Edge
last person joined: 11 hours ago
WOL not working on 3810M 802.1X locked down interface
  • 1.  WOL not working on 3810M 802.1X locked down interface
    Posted Aug 19, 2022 10:50 AM
    Hi all.
    I'm struggling to lock down any switchports on an Aruba 3810M switch stack (KB.16.11.0004) and have WOL continue to work, which is essential for our environment.
    As I understand it, I should just need to specify "aaa port-access 1/43 controlled-direction in" and it should just work. WOL works fine against the test PC until I enable 802.1X with "aaa port-access authenticator 1/43". What am I missing?
    The test switch port config looks like this:
    interface 1/43
      untagged vlan 1
      aaa port-access controlled-direction in
      exit
  • 2.  RE: WOL not working on 3810M 802.1X locked down interface
    Posted Aug 22, 2022 11:09 AM
    Is VLAN1 the VLAN where you send out the wake-on-LAN (WOL) packets?
    In unauthenticated mode, you should see traffic for VLAN 1 on port 1/43.
    If you don't, what do you see for the commands:
    show port-access clients
    show port-access clients 1/43 detailed​
    So, set the untagged VLAN to the VLAN where you send out your WOL packets.
    Are you running in 'role-based' mode (aaa authorization user-role enable)? In that case, link the initial-role to the VLAN on which you send out your WOL packets.
