Would token caching help with AP Roaming?
  • 1.  Would token caching help with AP Roaming?
    Posted Oct 29, 2014 09:43 AM
    I seem to have roaming issues between AP's. I use 802.1x authentication and the clients seem to fail when trying to roam to another AP. Would token cacheing keep the clients from haveing to reauthenticate to each AP as they roam or am I understanding that wrong?
    Thanks!
  • 2.  RE: Would token caching help with AP Roaming?
    Posted Oct 29, 2014 09:56 AM
    Are these APs attached to the same controller ?
    Do you have the APs added to the same AP-Group ?
  • 3.  RE: Would token caching help with AP Roaming?
    Posted Oct 29, 2014 11:45 AM
    Yes. Single Controller all in the default group. Mix of 105's, a 135, and some 225's
  • 4.  RE: Would token caching help with AP Roaming?
    Posted Oct 29, 2014 12:40 PM
    What type of devices are you using ? Windows , Apple, Android ?
    What version OS are you using ? Do you have ClientMatch enabled?
