WPA2-Enterprise and Captive Portal on a "Guest" Network?
  • 1.  WPA2-Enterprise and Captive Portal on a "Guest" Network?
    Posted May 04, 2012 10:25 AM
    I have an Aruba Instant, and I'm trying to create a "guest" network, that has WPA2-Enterprise authentication/encryption, rather than a PSK, which seems to be the only option in the web interface.  I would use a non-guest network type, which allows WPA2-Ent, however, then the option for a captive portal disappears.
    What are my options?
    Thanks.
  • 2.  RE: WPA2-Enterprise and Captive Portal on a "Guest" Network?
    Posted May 08, 2012 06:40 PM
    You can't have open guest SSID and perform dot1x authentication.
    what you can do is set the new SSID as open/guest and then in the security tab of that workflow choose to enable encryption with the following choices:
    - WPA2 personal
    - WPA personal
    - both (WPA2-WPA)
    - static WEP
    -Ariya
