Does it cause client connectivity issues?
Does this happen on many clients?
On all clients or on specific clients?
Does this happen regularly, or sporadically?
If it happens sporadically, you probably can just ignore it. If it happens on specific clients, you may try to upgrade that client or the wireless drivers.
It may also be someone trying to scan or attack your network.
I'm not aware of a generic fix, so reaching out to Aruba TAC may be the proper next step.
Original Message:
Sent: Jul 17, 2024 11:24 PM
Subject: WPA2 Key message 2 from Station did not match the replay counter 01 vs 02
ArubaOS (MODEL: Aruba7220), Version 8.10.0.10 LSR have following messages in logs:
Duplicate Correlation: Check Children for single Events: Major Syslog Message : dot1x-proc: 2[11633]: <138093> <11633> <ERRS> <wc-02 100.200.3.4>
WPA2 Key message 2 from Station 7c:2a:ca:68:d2:a9 b0:1f:8c:05:b4:22 ap-011804 did not match the replay counter 01 vs 02
How this can be fixed ?
