WPA2-MPSK import from XML
  • 1.  WPA2-MPSK import from XML
    MVP EXPERT
    Posted Mar 25, 2019 06:02 PM
    I have been playing with the new WPA2-MPSK for a few days now. I configure my services in CPPM and use the guest module to add devices. This works as expected.
    But now I have a challenge to import endpoints from an xml file. What I want to achieve is to import a list of mac addresses and WPA2 keys as bulk. I do not want to use the automatically generated keys for this.
    The "mpsk" field is used in the guest module. But when I add it to my import / export list, the keys are not visible or imported.
    When I look in the CPPM service I cant edit the Radius: Aruba "Aruba-MPSK-Passphrase" attribute with a variable that matches my keys. I only see an option to automatically generate the radius attribute a key.
    I would like to be able to import a list into the guest device database with mac addresses and custom wpa2 keys. I would like to achieve this to migrate from a different brand wlan environment to Aruba. The old environment uses the MPSK per device principle and i would like to import the WPA2 keys per devices 1:1 so that the user does not notice this.
    Is this possible, and is there maybe allready a good manual arround of the new WPA2-MPSK functionality, it would be very welcome.
  • 2.  RE: WPA2-MPSK import from XML
    Posted Mar 26, 2019 12:07 PM
    You need to add two fields to your spreadsheet: mpsk and mpsk_enable
    You'll see that they both come in as auto-detected fields for "Wi-Fi Password"
  • 3.  RE: WPA2-MPSK import from XML
    MVP EXPERT
    Posted Mar 26, 2019 04:31 PM
    Jfox, a lot of thanks for this tip. My issue was i first edit my export template, make a export en replace the values. But at this first row i see "WiFi-Password" two times. When i change the first row with "mpsk" and "mpsk_enabled" it works as aspected. THANKS!
    Is there also a option to export the Keys? When i export with the "mpsk" field it remains empty :(.
  • 4.  RE: WPA2-MPSK import from XML
    Posted Mar 26, 2019 04:46 PM
    I also see an empty field when I export a CSV.
    Per Tim Cappalli, there is not a way to bulk export keys.
