Comware
wrong duplicate IP error messages on A5500
  • 1.  wrong duplicate IP error messages on A5500
    Posted May 30, 2013 12:12 PM
    I am setting up 3 A5500 switches to be deployed and I get duplicate IP address errors anytime I connect a device to one of the switches.
    It only happens on one switch, I can clear the ARP table on all the switches and it does not make any difference. For some reason it always comes back saying that the address is already used on another port (the port is Gi1/0/52 and is the access link to the other switch)
    All switch ports on same VLAN, and no trunk ports.
    There is nothing else connected on these switches and there are definitelly no duplicate addresses tha would cause these errors.
    Apr 26 13:33:50:066 2000 BCC10-RM150 ARP/5/ARP_DUPLICATE_IPADDR_DETECT: Detected an IP address conflict. The device with MAC address 001b-38be-da74 connected to GigabitEthernet1/0/52 in VLAN 60 and the device with MAC address 001b-38be-da74 connected to GigabitEthernet1/0/18 in VLAN 60 are using the same IP address 132.156.60.100.
    I have tried with 2 different devices that have different addresses and get the same result for both. Firmware was updated to the most current one an all the switches.
    display version
    HP Comware Platform Software
    Comware Software, Version 5.20.99, Release 2220P02
    Copyright (c) 2010-2013 Hewlett-Packard Development Company, L.P.
    HP A5500-48G-PoE+ EI Switch with 2 Interface Slots uptime is 0 week, 0 day, 1 hour, 46 minutes
    HP A5500-48G-PoE+ EI Switch with 2 Interface Slots with 1 Processor
    256M bytes SDRAM
    32768K bytes Flash Memory
    Hardware Version is REV.C
    CPLD Version is 002
    Bootrom Version is 707
    [SubSlot 0] 48GE+4SFP+POE Plus Hardware Version is REV.C
    [SubSlot 1] 2 SFP+ Hardware Version is REV.A
    [SubSlot 2] 2 SFP+ Hardware Version is REV.A
  • 2.  RE: wrong duplicate IP error messages on A5500
    Posted Jun 03, 2013 10:34 AM
    More information in case it helps get an answer:
    I am setting up 3 A5500 switches to be deployed and I get duplicate IP address errors anytime I connect a device (PC) to switch1 and ping the PC from it's console port.
    Switch1 132.156.60.3 /23  (really 2 A5500 switches stacked through 10Gb ports at the back so 1 appears as 1 switch)
    [switch1]display irf configuration
    MemberID NewID IRF-Port1 IRF-Port2
    1 1 Ten-GigabitEthernet1/1/1 Ten-GigabitEthernet1/2/1
    Ten-GigabitEthernet1/1/2 Ten-GigabitEthernet1/2/2
    2 2 Ten-GigabitEthernet2/1/1 Ten-GigabitEthernet2/2/1
    Ten-GigabitEthernet2/1/2 Ten-GigabitEthernet2/2/2
    Switch2 132.156.60.13 /23
    switch3 132.156.60.14 /23
    Switch1 connected by Gi1/0/52 to switch2 Gi1/0/25, swtch2 connetced by Gi1/0/26 to switch3 Gi1/0/25
    PC1 (connected to switch1 Gi1/0/40) 132.156.60.200 /23
    PC2 (connected to switch2 Gi1/0/12) 132.156.60.100 /23
    This error only happens on switch1, I can clear the ARP table on all the switches and it does not make any difference. For some reason it always comes back saying that the address is already used on  port is Gi1/0/52 which is the access link to switch2
    There is nothing else connected on these switches and there are definitelly no duplicate addresses that would cause these errors.
    I have tried with the 2  PCs that have different addresses and get the same result for both. Firmware was updated to the most current one an all the switches.
    display version
    256M bytes SDRAM
    CPLD Version is 002
    <switch1>display arp
    Type: S-Static D-Dynamic
    IP Address MAC Address VLAN ID Interface Aging Type
    132.156.60.200 0015-609c-c17c 60 GE1/0/40 18 D
    132.156.60.13 d07e-2884-0c7f 60 GE1/0/52 4 D
    132.156.60.100 001b-38be-da74 60 GE1/0/52 20 D
    From console on switch1, I then ping directly connetcted PC1 and immediatelly start to get duplicate IP errors
    <switch1>ping 132.156.60.200
    PING 132.156.60.200: 56 data bytes, press CTRL_C to break
    %Apr 27 10:13:19:380 2000 BCC10-RM150 ARP/5/ARP_DUPLICATE_IPADDR_DETECT: Detected an IP address conflict. The device with MAC address 0015-609c-c17c connected to GigabitEthernet1/0/40 in VLAN 60 and the device with MAC address 0015-609c-c17c connected to GigabitEthernet1/0/52 in VLAN 60 are using the same IP address 132.156.60.200.
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
    --- 132.156.60.200 ping statistics ---
    5 packet(s) transmitted
    0 packet(s) received
    100.00% packet loss
    132.156.60.13 d07e-2884-0c7f 60 GE1/0/52 3 D
    132.156.60.200 0015-609c-c17c 60 GE1/0/52 20 D
    If I disconnect Switch1 Gi1/0/52, no errors are reported. Also this error does not happen on the other 2 switches if I connect the PCs to them and ping them.
    [switch1]display current-configuration
    version 5.20.99, Release 2220P02
    sysname switch1
    irf mac-address persistent timer
    irf auto-update enable
    undo irf link-delay
    domain default enable system
    undo ip http enable
    password-recovery enable
    vlan 1
    vlan 60
    domain system
    access-limit disable
    state active
    idle-cut disable
    self-service-url disable
    user-group system
    group-attribute allow-guest
    cwmp
    undo cwmp enable
    interface NULL0
    interface Vlan-interface60
    ip address 132.156.60.3 255.255.254.0
    interface GigabitEthernet1/0/1
    port link-mode bridge
    port access vlan 60
    (all ports repeat same config until Gi2/0/28)
    interface GigabitEthernet2/0/28
    port access vlan 60
    shutdown
    interface Ten-GigabitEthernet1/1/1
    interface Ten-GigabitEthernet1/1/2
    interface Ten-GigabitEthernet1/2/1
    interface Ten-GigabitEthernet1/2/2
    interface Ten-GigabitEthernet2/1/1
    interface Ten-GigabitEthernet2/1/2
    interface Ten-GigabitEthernet2/2/1
    interface Ten-GigabitEthernet2/2/2
    load xml-configuration
    load tr069-configuration
    user-interface aux 0 1
    user-interface vty 0 15
    irf-port 1/1
    port group interface Ten-GigabitEthernet1/1/1 mode normal
    port group interface Ten-GigabitEthernet1/1/2 mode normal
    irf-port 1/2
    port group interface Ten-GigabitEthernet1/2/1 mode normal
    port group interface Ten-GigabitEthernet1/2/2 mode normal
    irf-port 2/1
    port group interface Ten-GigabitEthernet2/1/1 mode normal
    port group interface Ten-GigabitEthernet2/1/2 mode normal
    irf-port 2/2
    port group interface Ten-GigabitEthernet2/2/1 mode normal
    port group interface Ten-GigabitEthernet2/2/2 mode normal
    return
    Any insights?
  • 3.  RE: wrong duplicate IP error messages on A5500
    Posted Aug 31, 2013 04:46 PM
    Did you get any solution for the problem ? I'm with the same problem here, messages ARP_DUPLICATE_IPADDR_DETECT, but i'm sure that there isn't duplicated MAC. I've two A5500 and i'm using IRF too.
    Tks
  • 4.  RE: wrong duplicate IP error messages on A5500
    Posted Oct 30, 2013 09:46 AM
    Does anyone have a sollution for this problem, i have the same issue.
  • 5.  RE: wrong duplicate IP error messages on A5500
    Posted Dec 03, 2013 03:23 AM
    Same problem here, has anyone found a solution?
    Kind regards,
    Kris
  • 6.  RE: wrong duplicate IP error messages on A5500
    Posted Dec 03, 2013 12:48 PM
    system-view
    mac-address mac-roaming enable
     Let´s see whether this will help...
    As alway try latest firmware (boot-loader and bootrom): R2220P10
  • 7.  RE: wrong duplicate IP error messages on A5500
    Posted May 13, 2014 02:15 PM
    Hi Michael,
    Which switch models would you expect that command to be available on?  I've got a 3100 EI v2 on 5203P03 reporting this message, but there's no sign of the mac-roaming option.
  • 8.  RE: wrong duplicate IP error messages on A5500
    Posted May 13, 2014 02:25 PM
    And a quick follow-up: this page suggests that "arp ip-conflict prompt" might be useful http://translate.google.com.au/translate?hl=en&sl=zh-CN&u=http://forum.h3c.com/forum.php%3Fmod%3Dviewthread%26action%3Dprintable%26tid%3D141911&prev=/search%3Fq%3D%2522ARP_DUPLICATE_IPADDR_DETECT%2522%26hl%3Den%26biw%3D1920%26bih%3D959
    However, the manuals suggest that this is related to gratuitous ARP, not ARP in general (although in my case the ARP frame may be gratuitous).
  • 9.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 23, 2015 07:13 AM
    Hi there
    did any of you find the cause and solution to this problem. We are seeing the same error, and we are also using A5500 in IRF.
    BR
    Bo
  • 10.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 16, 2016 12:13 PM
    Hi.
    I have the same issue on my environment.
    The scenario is:
    1 HP A5500 HI 48G as the network core.
    5 HPE V1910 48G connected to the core switch through a 2GB LAG each switch.
    1 Cisco ASA 5505 plugged in the GI1/0/48 (core).
    Some VLANs was created in the switches.
    The default gateway of the network is the switch core and they has a static route, routing all the traffic to the firewall.
    The firewall has a static route, routing all the traffic to the WAN IP.
    I'm quite sure about the LAN's IP addresses and every day I receive a message posted below:
    Detected an IP address conflict. The device with MAC address 7081-05be-9b7e connected to Bridge-Aggregation5 in VLAN 1 and the device with MAC address 7081-05be-9b7e connected to Bridge-Aggregation7 in VLAN 1 are using the same IP address 192.168.11.23.
    But this specific device is plugged in in the Switch called 7 in the network. The LAGs received the number that corresponds to the switch name to identify the traffic.
    What should I do to solve this issue?
    Thanks in advance.
  • 11.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 16, 2016 02:48 PM
    From the number of users reporting this, a loop in your networks seems unlikey.  If you're already running latest A5500 firmware, try command from google translate link above to mask this error.
  • 12.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 16, 2016 08:46 PM
    Does the commands will only mask or will solve the problem?
    I'm asking this because I'm thinking that the problem perhaps can be caused by an out of date NIC driver. Or am I wrong thinking this way?
    Thanks.
  • 13.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 17, 2016 02:01 AM
    Highly unlikely that a faulty NIC driver will loopback received packets.
    If these message are really caused by an issue on the network, the NIC with mentioned IP & MAC address isn't to blame.
    Troubleshooting should focus on finding loopback on network port/segment where the duplicate address is detected
  • 14.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 17, 2016 06:04 AM
    I have two buildings interconnected by a layer 2 ISP switches. The company is in the building #1 and our datacenter is in the building #2.
    In the #2 I have another HPE V1910 48G and to provide access to a video solution, another switch (Dell) is plugged in the HPE through a fibre channel.
    Yesterday I powered off this uplink to the Dell switch and "magically" the duplicated IP addresses alarm stopped from appear in the core switch. So I started to think that with this topology (each switch plugged in directly to the core (LAG 2GB)) I can not plug in another switch in the network that is not plugged directly to the core switch. This is my doubt now.
    I appreciate the answers and as soon as possible I will post another comments.
    EDIT #1: In my case this is a problem related to the NETBios name too. The company has some OS X workstations.
    Thanks in advance.
  • 15.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 17, 2016 09:42 AM
    You should be able to plug in extra switch behind 1910 without problems.....as long as you're not creating a loop anywhere. Do 1910 and dell logs show related events?
  • 16.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 17, 2016 02:39 PM
    Dell does not show nothing. HPE sometimes show the log error "gi1/0/x is up, down, up,down" but nothing more than that. I found today some machines alarming in the core switch and I discover that was the WINS server. I stopped the WINS and remove the option in the DHCP scope to distribute the wins (44 and 46 options). Now the OSx does not alarming anymore.
    Another strange behaviour that happens is when I do a reboot in the server (can be the file server for an example) all other machines over the LAN loses the internet communication. In the afternoon today the building loses the electricity but the technical room has a no break to avoid this scenario because it happens almost one or two times per week. Speaking the truth, all the company loses the internet connection. I was forced to reboot the core, cleaning the arp table of all other switches. Unsatisfied I rebooted the core again and after this I was able to ping the firewall. :/
    It is very strange.
    RSTP is active only in the core switch with BPDU protection. All other switches are disable even the Dell that I disable RSTP today.
    I am starting to think to left this area.
    Thanks a lot.
  • 17.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 17, 2016 03:48 PM
    Why not use STP on other switches too?  It's designed to break loops, and maybe a loop is causing this
  • 18.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 18, 2016 04:05 AM
    Should I enable rstp on all other boxes even if the rstp is enable on the core switch? I think if the core is the default gateway and the network core (routing everything) and all other switches are plugged in in the core, I don't need to enable in other switches, because the root of the network is controlling this. But I'm seeing that I'm wrong to think that. There's at least 8 vlans created in the switches, all 1910 has only the VID and the 5500 has the VID with the ip which is the gateway of that vlan. Can I assume the rstp default values in a port based vlan? Thank you.
  • 19.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 18, 2016 10:32 AM
    On a routed network, there's still a place for STP on the access switches.  You will get multiple stp  domains.   Use bpdu guard on access ports, so if you do interconnect access switches by accident, this link will block so packets can't leak to wrong core interface
  • 20.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 18, 2016 10:48 AM
    Ok. Do I use the default values when enable rstp in the access switches? Enabling rstp can cause a loss of connectivity?
    Sorry for the number of questions.
    I let you know about the procedure.
    Thanks.
  • 21.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 18, 2016 02:59 PM
    at least, make sure STP root priority on root is superior (=lower).
    If somehow a single STP domain is created , instead of multiple domains across L3 links, ports from core will never be blocked by STP
  • 22.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 18, 2016 06:45 PM
    I did not realize this procedure yet and I have the follow situation.
    When I shutdown the core switch port (GI1/0/2 - L2 through ISP switches to the building #2 for an example) I loss the conectivity with the machines inside the building #1.
    Through LLDP neighborhood I am unable to discover the building #2 leg.
    I have a VPN tunnel from Equinix Data Center to the environment #1, so I log in in the core through this VPN and reboot the device. After this the machines appear online again and I am able to ping some specific devices through this tunnel.
    This is a very strange behaviour. Yesterday I reboot the domain controller and the same situation happen, loss of conectivity obligating me to reboot the device.
    Do you think that RSTP can solve this breaks?
    Again, thanks in advance.
  • 23.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 19, 2016 02:39 AM
    Normally after STP changes, the network should converge .  After rebooting a switch, the network should converge....to the same situation.
    However if some port protection mechanisms (like port security , bpdu guard) has kicked in, and no auto-recovery is configured, a reboot is a way to get connectivity back.   (a crude way I might add)
    Prior to reboot, review switch log files
  • 24.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 20, 2016 05:07 PM
    Well, what I did last friday I will list below. All procedures are did on the core switch.
    Through ssh connection I list the stp brief.
    All ports was listed as "forwarding" and BPDU protection are disabled.
    So, in the ports that are connected the servers I did the command enable stp edge-port. After this the BPDU protection is enable listing in stp brief.
    A doubt appear after. The GI1/0/48 is the firewall ASA 5505 port. Should I enable stp edge-port in this port too?
    After this procedure I did the command undo shutdown on the GI1/0/2 which is a trunk port to the building #2. The convergence time was the loss of 8 pings to the firewall and it starts to ping again but I think the convergence time could be more faster or am I wrong?
    Thanks in advance 16again.
    EDIT #1: About auto recovery. Where I can enable this feature?
  • 25.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 21, 2016 03:05 AM
    The ASA5505 doesn't run STP, so you can use edge port settings.
    Port recovery is configured with "shutdown-interval <number of seconds>" command.
    Default recovery =30 seconds, don't set to 0 (=no recovery)
    On the ISP L2 link, you might consider blocking all incoming/outgoing BPDUs on attached ports. There's only one path between building so loops can't be formed there.
    Are you running a routing protocol? If the 5500 route table is messed up, you'll also lose connectivity. (what's 5500 config?)
  • 26.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 23, 2016 12:10 PM
    Hi.
    I will do the command in the firewall port after the job hour.
    The core switch config is attached.
    How can I block the BPDU over L2 link port?
    Thanks a lot and I let you know about the procedure on GI1/0/48 (FW). I set up the shutdown-interval in 10 seconds.
    The routing table was automatically generated when the vlans was created. About the port description, it is wrong.
    Attachment(s)
    zip
    startup.cfg.zip   703 B 1 version
  • 27.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 23, 2016 02:47 PM
     use the interface command "undo stp enable" on specific port to disable spanning tree on the port
  • 28.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 06:31 AM
    I did the command undo stp in the L2 ISP link and stp edged enable in the firewall port.
    Did you see something wrong in the routing table?
  • 29.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 07:09 AM
    Based on my experience, this command don't filter BPDU frames (input, output) but only disables STP process for selected L2 port.
    Was your intention to exlude one port from STP process?
    Br,
    Michal
  • 30.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 07:17 AM
    This port is a trunk to another building and on the other edge has another L2 switch (HPE V1910).
    The intention was to disable BPDU not RSTP at all.
    The duplicated IP address messages still on but until now the LAN does not stop working.
    Thanks in advance.
  • 31.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 08:20 AM
    Your routing config is OK. No routing protocol used, and only direct attached routes and single default route
    @Mike_ES
    Disabling STP on a single port seems to me functional very close to a BPDU filter which blocks all in/out-going STP packets on the port.
    Do you have a better alternative command, mimicking cisco BPDU filter?
  • 32.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 08:28 AM
    @Mike_ES
    Please follow this link:
    http://h10032.www1.hp.com/ctg/Manual/c02583003
    e.g.
    <Sysname>system-view
    [Sysname] interface GigabitEthernet 1/0/1
    [Sysname-GigabitEthernet1/0/1] bpdu-drop any
    Important info:
    Not every Comware platform has this feature avaiable - for example HP 7506 Comware 5 doesn't have ;-)
    Michal
  • 33.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 08:45 AM
    So, do I need to maintain RSTP activate on this port and disable the BPDU traffic?
    About the LAGs, is it right to activate the RSTP on these ports? (Aggregation 2 GB).
    Thanks.
  • 34.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 24, 2016 10:18 AM
    @Mike_ES:
    Indeed usefull command, but the use case in your link seems to me like plain STUPID.
    If I want to block users from sending bogus BPDUs, a feature like bpdu-guard is a way better solution, without introducing the risk of creating loops.
    @it_ejvnior
    As soon as bpdu-drop is used, STP mode of that port has na effect. After all, STP packets are no longer allowed in/out of the port.
  • 35.  RE: wrong duplicate IP error messages on A5500
    Posted Feb 25, 2016 06:42 AM
    @16again The LAN is stable with the RSTP and BPDU activated in the workstation ports.
    The messages of duplicated IP addresses are less frequent than before but still appear sometimes. What I think it is strange is a duplicated IP address from a switch. I have full control of the LAN IP addresses and I am quite sure about the distributed addresses even the addresses out of the distribution range.
    I am thinking to fix the ARP table over the core switch but I do not know if it is a best practice and procedure to do and even if it will solve this issue.
    Thanks in advance my friend.
    EDIT #1: I'm reading some posts here and I found a RSTP config to the core switch as described below:
    stp timer hello 100
    stp timer forward-delay 400
    stp timer max-age 600
    My core switch has the following configuration:
    Forward Delay: 1500
    Hello Time: 200
    Max Age: 2000
    Instance ID 0
    Root Type Primary
    Bridge Priority 0
    Do I need to change the configuration diminishing the values for a more faster convergence?
    Thanks.
  • 36.  RE: wrong duplicate IP error messages on A5500
    Posted Mar 07, 2016 01:59 PM
    I think you mix two areas ;-)
    One area is the convergence time and second area are you case - duplicated IPs.
    I don't think that tuning RSTP timers will help you to resolve it
  • 37.  RE: wrong duplicate IP error messages on A5500
    Posted Mar 07, 2016 02:03 PM
    But tuning the RSTP config can help me in the covergence?
    Thanks for the reply.
  • 38.  RE: wrong duplicate IP error messages on A5500
    Posted Mar 12, 2016 08:33 PM
    I am facing the same problem.
    In my scenario I'm using IRF + LACP. I will analyze and post news here ..
  • 39.  RE: wrong duplicate IP error messages on A5500
    Posted Mar 15, 2016 11:36 AM
    I fix this checking all switches and all ports. Configuring each port that was misconfigured as an example, printer ports was as a trunk not access port. Checking the ports that need to be in access mode and checking the ports that has an access point attached to (in my case, a Cisco AP that forward tagged traffic) in hybrid mode and the Apple airport (access mode).
    Disabling in the Mac OS X the feature in energy save that able the machine to communicate with the airport over the LAN through bonjour proxy.
    This procedures doing with attention has fixed the issue and make my day more happy.
    Thanks a lot to everyone.
    Now I'm going to STP questions.
    EDIT#1: No, I'm wrong. This won't solve the issue. I'm still getting the messages.
    EDIT#2: The duplicated messages is solved. I changed all uplinks mode from static to dynamic, and the problem is gone.
    EDIT#3: The problem was solved changing the link aggregation mode from static to dynamic.
    #uplink
    #dynamic
    #static
    #bagg
