Wrong IPSec RAP Password
  • 1.  Wrong IPSec RAP Password
    Posted Aug 04, 2015 05:11 PM
    Hi all,
      i set a wrong ipsec password during a provision of a remote AP and now i lost the connection with the ap so i cannot set the correct one. Is possible to do something or do i need to reset the AP?
    Riccardo
  • 2.  RE: Wrong IPSec RAP Password
    Posted Aug 04, 2015 06:42 PM
    If you know the password you set, you can change the password on the controller to that password so that it can connect.  By the way, is this an 802.11n AP?  If so, you should be using the whitelist, not a password.
    If you don't know the password, you will have to reset the AP.
