We have implemented VLAN's at a site, but I am running into a issue with the new wireless controller (H3C WX5004, firmware 2107P10) and AP (WA2620-AGN). For some odd reason, the AP will not grab the correct DHCP Scope (Wireless VLAN 20, 10.60.32.x). Also, when users connect to the AP, they do not get a 10.60.32.x address; instead, they get the 10.60.0.x (PC VLAN). Both AP and user are getting the default VLAN address. I have gone through the controller and configure it to use the VLAN 20. The controller is off site which is not running VLAN's yet.
Switch Port (HP 4800-48G-POE) @ Site:
port link-type hybrid
port hybrid vlan 20 tagged
port hybrid vlan 1 untagged
voice vlan 30 enable
WX5004 (3C WX5004, firmware 2107P10)
vlan 1
vlan 20
wlan service-template 1 crypto
ssid VLANTest
beacon ssid-hide
bind WLAN-ESS 0
cipher-suite wep104
wep default-key 1 wep104 raw-key cipher
client forwarding-mode local vlan 20
service-template enable
interface Vlan-interface1
ip address x.x.x.x 255.255.240.0
interface WLAN-ESS0
undo port hybrid vlan 1
port hybrid vlan 20 untagged
port hybrid pvid vlan 20
#VLAN#2620#wx5004
