XML Device import into ClearPass 6.4
  • 1.  XML Device import into ClearPass 6.4
    Posted Apr 01, 2015 11:40 AM
    Below is an example of my XML file I am using to import devices into ClearPass 6.4.  There are actually over 1k devices in my final script, but this example shows one.  When I try to import, I get the error "Invalid XML tags, please export to see valid tags", which I've tried doing, but everything looks right.  What am I doing wrong?
    Thanks!
    <?xml version="1.0" encoding="UTF-8" standalone="true"?>
    <TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
    <TipsHeader version="6.4" exportTime="Wed Apr 01 08:54:02 EDT 2015"/>
    <NadClients>
    <NadClient ipAddress="10.1.0.22" radiusSecret="f0restc1ty" tacacsSecret="f0restc1ty" vendorName="Cisco" coaCapable="true" coaPort="3799" name="Arista-Higbee-7050S-TOR6-G11" description=""/>
    </NadClients>
    </TipsContents>
  • 2.  RE: XML Device import into ClearPass 6.4
    Posted Apr 01, 2015 11:42 AM
    Try and take out the TIPS header line.
  • 3.  RE: XML Device import into ClearPass 6.4
    Posted Apr 01, 2015 11:47 AM
    Nope....still the same message.
    "File contains invalid XML tags. Try export to see the valid XML tags."
  • 4.  RE: XML Device import into ClearPass 6.4
    Posted Apr 01, 2015 01:05 PM
    Can you try changing the format to this:
    <NadClients>
    <NadClient description="" name="CISCO-SWITCH" coaPort="3799" coaCapable="true" vendorName="Cisco" tacacsSecret="" radiusSecret="" ipAddress="192.168.1.116"/>
    </NadClients>
    </TipsContents>
  • 5.  RE: XML Device import into ClearPass 6.4
    Posted Apr 01, 2015 01:21 PM
    Aarrgh.....no, same thing
  • 6.  RE: XML Device import into ClearPass 6.4
    Posted Apr 16, 2015 09:19 AM
    It hates null values.. either put something in the description or remove the description=""
  • 7.  RE: XML Device import into ClearPass 6.4
    Posted Feb 01, 2018 03:10 AM
    Make sure the encoding of the xml-file is UTF-8.
