Youtube Wouldn't be blocked in instant integrated BEF
  • 1.  Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 04:38 AM
    I am trying to block youtube using the firewall roles which integerated in the Instant OS.
    I tried to block the youtube from:
    1. Application - Youtube
    2. Application Category - Streaming
    3. Web Category - Streaming-media
    It's working in some of PC's and phones not in the all network.
  • 2.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 06:35 AM
    What version of InstantOS is this?
  • 3.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 07:30 AM
    Version : 6.5.1.0-4.3.1.0_57768
  • 4.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 07:45 AM
    I tried also on 6.5.2.1_59704 its the same issue !!!
  • 5.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 07:58 AM
    Are you using the web version of Youtube or the Application You tube?  What OS?
  • 6.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 08:06 AM
    It seems that google has been using the 'quic' application to stream youtube videos.  You should try blocking the quic application to see if it makes a difference:
    any any app quic deny
  • 7.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 09:00 AM
    Yes Joseph Its blocked now after i blocked the "quic" application, but you can't access www.google.com now !!!
  • 8.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 10:09 AM
    So why don't you allow connections to www.google.com and then block the quic app?
  • 9.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 24, 2017 10:32 AM
    I already test to allow google before blocking the quic application, but google is still blocked. If i remove the quic application blocking google return to live agian.
    Please chech the snap shots.
    Thanks for your quick reply.
  • 10.  RE: Youtube Wouldn't be blocked in instant integrated BEF
    Posted May 29, 2017 08:24 AM
    I am still stuck in this case please advise.
