Wired Intelligent Edge
Zero Touch Provisioning, image problems
  • 1.  Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 02:57 AM
    We are trying to get zero touch provisioning to work for our 2930F switches. We don't want to use airwave or activate/central.
    Everything works fine and the switch get the correct configuration but I can't get the switch to download a new image firmware.
    I can't find any documentation how to configure image upgrade.
    This is my isc-dhcp configuration (read somewhere that Cisco switches ueses option 125 for image upgrade, doesn't work...):
    option configfile code 67 = text;
    option tftpserver code 66 = text;
    option imagefile code 125 = text;
    subnet 10.202.0.0 netmask 255.255.255.0 {
        range 10.202.0.10 10.202.0.200;
        option routers 10.202.0.1;
        option subnet-mask 255.255.255.0;
        host accesswitch {
            hardware ethernet e0:07:1b:34:0c:a0;
            fixed-address 10.202.0.5;
            option tftpserver "172.18.20.51";
            option configfile "CN68FP53DN.cfg";
            option imagefile YA_16_04_0011.swi;
    In my TFTP server I can't see any requests for the image file.
    Thanks!
  • 2.  RE: Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 04:38 AM
  • 3.  RE: Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 04:48 AM
    @cjoseph wrote:
    Zero touch provisioning only works with Airwave or Central.
    http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/K-KA-KB/16-01/5200-0137_MCG/content/ch11s07.html
    Well it is working with ZTP-configuration with only DHCP and TFTP server.
    Why would you have this command in place if it's only working with airwave?
    NS-0001# show dhcp client image-file-update
    Downloading Image File from TFTP server is enabled
    Log also shows the following:
    I 01/01/90 00:02:30 00092 dhcp: ST1-CMDR: Enabling Auto Image Config Download via DHCP and turning off auto-tftp if enabled
    Are you saying that DHCP/TFTP is viable only for configuration of device but if I want to upgrade, I need to use airwave?
    Thanks!
  • 4.  RE: Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 05:04 AM
    Let's take a step back.
    Do you want to upgrade your firmware and distribute configuration via TFTP?
    Zero-Touch is the brand name for a specific process that requires Airwave or Central.
  • 5.  RE: Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 05:08 AM
    Yes I want to upgrade firmware and distribute configuration using only DHCP options and TFTP.
    Sorry if I confused you with the ZTP acronym.
  • 6.  RE: Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 05:50 AM
    Good morning, I was just taking a look at this thread and noticed that you stated that you are using a 2930F but for some reason it looks as if you are tying to load incorrect firmware “YA_16_04_0011.swi”.
    Can you try it with the “WC_16_04_0011.swi” and see if you still get the same results? depending on the switch model number, even though the “16_xx_xxxx.swi” looks the same, each model will start with a different identifier “ya, wc, wb, kB, k, etc”.
    Benny
  • 7.  RE: Zero Touch Provisioning, image problems
    Posted Jan 24, 2018 06:22 AM
    Benny
    Actually I was doing this with a 2530 for LAB, sorry for the confusion. In production we use 2930F.
  • 8.  RE: Zero Touch Provisioning, image problems
    Posted Jan 26, 2018 03:34 AM
    Hello, found the solution. The DHCP sub-option 145 needs to be encapsulated inside DHCP option 43. Sub-option 144 can also be used to specify configuration file.
    Here is the DHCP configuration file:
    option space NEW_OP;
        option NEW_OP.image-file-name code 145 = text;
        option NEW_OP-encapsulation code 43 = encapsulate NEW_OP;
    subclass "vendor-class" "HP J9774A 2530-8G-PoEP Switch                            dslforum.org" {
          option vendor-class-identifier "HP J9774A 2530-8G-PoEP Switchdslforum.org";
        option NEW_OP.image-file-name "YA_16_04_0011.swi";
  • 9.  RE: Zero Touch Provisioning, image problems
    Posted Jan 05, 2022 11:04 PM
    Thank You for sharing this.
    Added some more for the DHCP Option on some of the CX switches.
    ### Begin Config for ISC DHCP Server dhcpd.conf #####
    # Aruba CX ZTP provisions #
    # https://www.arubanetworks.com/techdocs/AOS-CX/10.07/HTML/5200-7852/Content/Chp_ZTP/ztp-sup-aos-cx-10.htm
    option space ArubaCX;
    option ArubaCX.config-file-name code 144 = text;
    option ArubaCX.image-file-name code 145 = text;
    option ArubaCX.CentralOnPrem-FQDN code 146 = text;
    option ArubaCX-encapsulation code 43 = encapsulate ArubaCX;
    #Class to Match Option 60
    ​class "Vendor-Class" {
    match option vendor-class-identifier;
    #SubClass Definiions
    # To Get Vendor Class for Switch CLI command on switch:
    # show dhcp client vendor-class-identifier
    # Aruba CX Lab OVA
    subclass "Vendor-Class" "Aruba ABC123 ArubaOS" {
    vendor-option-space ArubaCX;
    option ArubaCX.config-file-name "CXLab.cfg";
    option ArubaCX.image-file-name "filename.swi";
    option tftp-server-name "172.18.20.51";
    # Aruba 6200F 48 Port
    subclass "Vendor-Class" "Aruba JL728A 6200F" {
    option ArubaCX.config-file-name "6200F-24Port.cfg";
    option ArubaCX.image-file-name "ArubaOS-CX_6200_10_09_0002.swi";
    # Aruba 6200F 24 Port
    subclass "Vendor-Class" "Aruba JL725A 6200F" {
    option ArubaCX.config-file-name "6200F-48Port.cfg";
    # Aruba 6300 48 Port
    subclass "Vendor-Class" "Aruba JL659A 6300" {
    option ArubaCX.config-file-name "6300-48Port.cfg";
    option ArubaCX.image-file-name "ArubaOS-CX_6300_10_09_0002.swi";
    ### End Config for ISC DHCP Server dhcpd.conf #####
  • 10.  RE: Zero Touch Provisioning, image problems
    Posted Oct 31, 2023 11:21 AM
    Vielen Dank für deine Lösung, funktioniert bestens.
    Wäre es möglich, einer bestimmten MAC-Adresse ein bestimmtes Konfigurationsfile zuzuweisen?
    Ich würde neue Switches gerne automatisiert mit einem neuen Firmware-Image versehen und eine Konfigurationsdatei passend für den Switch installieren.
