Hi Herman,
Thanks for the info.
The devices are indeed paired with the AP:
AP505# show ap deb zigbee client-table
Zigbee Client Table
IEEE Address Name NWK Address Radio Seen Role Relationship RSSI LQI Last Update Uptime
84:2e:14:ff:fe:76:a6:77 -- b336 20:4c:03:ff:fe:a5:f4:7a ZED child -- -- 24218s 6h:43m:39s
0c:43:14:ff:fe:a0:58:40 -- 3d6d 20:4c:03:ff:fe:a5:f4:7a ZED child -- -- 24218s 6h:43m:39s
Total Zigbee client(s):2
b336 is the Styrbar, 3d6d is the Tråfri. It takes the Trådfri a very long time to associate, but it manages after about 5 or 6 attempts. I haven't done a deep dive on those traces yet.
Next step is to get the southbound traffic to work, so I can generate a packet in node-red, protobuf encode it and then see it on my Zigbee sniffer. I've gotten so far as to see the packet arrive on the AP, but then it stops.
Also, if I look at the incoming protobuf packets from the AP, the MAC adresses and the payload are unencoded. They should be base64 encoded, but that doesn't happen.
Incoming data from AP after protobuf decode:
{"radioMac":"IEwD//6l9Ho=",
"report":{
"mac":"hC4U//52pnc=",
"e2pc":{
"destination":{
"endpoint":1,
"profileId":260,
"clusterId":6
"sourceEndpoint":1
"payload":"AREB"
After manual base64 decoding of the radioMac, mac and payload values in the packet:
{"radioMac":"204c03fffea5f47a",
"report":{
"mac":"842e14fffe76a677",
"e2pc":{
"destination":{
"endpoint":1,
"profileId":260,
"clusterId":6
"sourceEndpoint":1
"payload":"011101"
Could this be a bug? Or am I misunderstanding something?
Steven
Steven Demets
Original Message:
Sent: Jan 14, 2022 10:56 AM
Subject: Zigbee addressing support question
Steven,
Cool that you tried to set this up and got to this point already. I wasn't even aware that this would work with Nodered; and didn't hear anyone coming as close as you seem to have got. You may, or may not have found this documentation, which I think is useful. From the captures above, it looks like you create a filter from endpoint 1 to endpoint 1, but the Trådfri is doing a kind of group broadcast, which may not be caught by a filter.
Did you pair these devices? Or are these just factory-default?
I probably won't be able to help too much as this is beyond what I have done before.
Original Message:
Sent: Jan 14, 2022 08:53 AM
I'm running an AP-505 in IAP setup with AOS 8.9.0.1.
I've created an IoT setup with IKEA buttons over the internal Zigbee radio and it works using the Zigbee Socket Device (ZSD) method and a websocket-telemetry transport profile.
For the IKEA Styrbar button I've created the following Zigbee socket-profile:
inbound 1 1 0104 6
inbound 1 1 0104 8
inbound 1 1 0104 5
And this gives me the appropriate responses on my server (node-red with a websocket input node and a protobuf decoder node using the AOS 8.9 .proto files from ASP) when I press the on/off and left/right buttons.
However, when I try the same with the (older and cheaper) IKEA Trådfri, I get no response at all from the on/off buttons.
After sniffing traffic from both buttons, I see the difference is in the Application Support sublayer (APS) delivery mode. The Styrbar uses destination endpoint addressing, while the Trådfri uses group addressing.
As far as I can tell, there is no way to define a group address as destination in the Zigbee socket-profile.
Is there any other way to get the AP to take in the Zigbee message and send it to my server?
Following is a capture of one APS packet from both buttons. The differences are in bold.
Styrbar (working):
ZigBee Application Support Layer Data, Dst Endpt: 1, Src Endpt: 1
Frame Control Field: Data (0x00)
.... ..00 = Frame Type: Data (0x0)
.... 00.. = Delivery Mode: Unicast (0x0)
..0. .... = Security: False
.0.. .... = Acknowledgement Request: False
0... .... = Extended Header: False
Destination Endpoint: 1
Cluster: On/Off (0x0006)
Profile: Home Automation (0x0104)
Source Endpoint: 1
Counter: 139
Trådfri (not working):
ZigBee Application Support Layer Data, Group: 0x0000, Src Endpt: 1
Frame Control Field: Data (0x0c)
.... 11.. = Delivery Mode: Group (0x3)
Group: 0x0000
Source Endpoint: 1
Counter: 197
Thanks for any advice/help,
Steven Demets
