Zoned APs
  • 1.  Zoned APs
    Posted Aug 25, 2017 11:25 AM
    If I stick an AP in a zone with one SSID, will it continue to broadcast the rest?
    I need to add an SSID to a single AP but want the current networks to keep broadcasting...
  • 2.  RE: Zoned APs
    Posted Sep 06, 2017 04:15 PM
    Yes, Any SSID which is not assigned to a zone will broadcast from all IAPs in the cluster, even though that are assigned to a zone.
    The following constraints apply to the zone configuration:
    • An IAP can belong to only one zone and only one zone can be configured on an SSID.
    • If an SSID belongs to a zone, all IAPs in this zone can broadcast this SSID. If no IAP belongs to the zone configured on the SSID, the SSID is not broadcast.
    • If an SSID does not belong to any zone, all IAPs can broadcast this SSID.
    http://community.arubanetworks.com/t5/Learning/Deploying-Aruba-IAP-Zones/td-p/300206
