Access Points
Highlighted
Re: Serial Over Ethernet Breakout Cable
Just re-crimp the Ethernet plug pins to
green 4
yellow 5
red 7
orange 8
(Credit to Colm Connor)
many thanks niall.king & colm connor!
Highlighted
Occasional Contributor I
Hi Experts,
I recrimped the Cisco Console cable exactly as described, and connected it to the AP ethernet port and the serial to my laptop. Used the power adapter to power up the AP.
but then nothing!
Please help me if I missed anything.
Highlighted
by the way, it is Aruba AP-65
Highlighted
Please look at the diagram here http://community.arubanetworks.com/aruba/attachments/aruba/70/41/1/SOE.jpg
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Thanks.
The Cisco Console didn't work. But re-wire the console according to the diagram works. :)
However, for some reason when I hit <Enter> on the console to stop the autoboot, it didn't work. The AP continue to boot as normal.
Any idea?
Highlighted
Make sure you have NO flow control in your terminal program.
Highlighted
yes, my setting is like this
bits per sec: 9600
Data bits: 8
Flow Control: No
Stop bits: 1
Highlighted
You have to hit Enter before the countdown stops.  I would start hitting enter when the AP starts booting.
Highlighted
Sorry, but that doesn't work either.
BTW, do you know if I can manage this AP through CLI/GUI without the management controller?
Highlighted
You cannot.
Let's get to the point:
When was the last time that this access point worked, and what controller/AOS version are you trying to get it to work with?
