ArubaOS and Controllers
Highlighted
Re: How do we do packet capturing on ArubaOS?
if you do a show user-table internal, you will see the ip address of the AP and role it has. That is the APs role and you can see the ACL by doing "show rights "
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Frequent Contributor I
So I assume I won't be able to capture packets from remote APs, but what If I have campus APs set up? I should be able to capture packets from them right? I did the show-user-table internal and it shows nothing on the controller for the campus APs. So where would I add that udp 5555 acl?
Highlighted
To be clear, campus APs work fine, because they get internally routable addresses. Remote APs do not, because by default they do not get internally routable addresses, so they cannot send their traffic to your station.
Highlighted
Yes, now I understand that remote APs won't allow me to capture packets. However I would like to capture them from the Campus APs, but I don't see any roles when I run that command show user-table internal, so I don't know where to add the acl or do I even need one?
Highlighted
Do not need one. Campus APs should just work.
Highlighted
Follwing the instructions here, I was able to get the remote capture to wireshark working; however, we use enterprise encryption and all I get is the 802.11 packets from my client laptop.
found an old wireshark doc dated around 2009 that says enterprise encryption is not currenly supported, but I was hoping someone here knew a way to get past that since its over a year ago.
Highlighted
MVP Guru Elite
it is still not supported ...
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
about aruba and wireshark
Highlighted
Hi
With the last release of Wireshark, there is support of Aruba ERM (Encapsultated remote Mirroring)
To activate this option, in Wireshark Preferences => Protocols => Aruba ERM => Aruba ERM Ports Number : 5555
Can you elaborate on how you can then use this to capture the traffic from the controller? This doesn't add it as an interface.
Cheers
James
Highlighted
MVP
Simply capture on the interface you're sending the stream to and apply the aruba_erm filter to get just the capture.
In the example below I've redirected the stream to my standard wired network interface and voila..
Koen (ACMX #351 | ACDX #547 | ACCP)
-- Found a post helpful or important? Click the "Thumbs Up" icon to give kudos.
