Problem:
Whenever you attempt to run a RRM Analysis manually, the below error is generated:
You will also see these events in the system logging:
Mar 14 13:58:53.697 debug 44:1E:A1:C2:58:5C rfmgr_sc: Entering severe interference state.
Mar 14 13:58:53.712 debug 44:1E:A1:C2:58:5C rfmgr_sc: [94:57:A5:89:82:A0] Severe Interference: Send provisional channel (108) ext (1), with delay metric of (0.042387), goToMax=0, AP metric=0.359245.
Mar 14 13:58:53.755 debug 44:1E:A1:C2:58:5C rfmgr_sc: [94:57:A5:89:82:A0] HandleChannelChangedEvent: Cause=[LocalInterference], OldChannel=[108], NewChannel=[108].
Mar 14 13:58:53.756 debug 44:1E:A1:C2:58:5C rfmgr_sc: [94:57:A5:89:82:A0] Severe interference handled.
Mar 14 13:58:54.365 debug 44:1E:A1:C2:58:5C rfmgr_sc: Exiting severe interference state.
Bigger environmental sites will most likely experience this issue more frequently. This is because the Severe Interference Detection/Mitigation feature is enabled more often.
This feature’s main function is to detect interference and will change the radio reconfiguration to use a new/different channel.
This changes the system’s status as “Not Stable” and thus, prevents the analysis to execute.
This behavior is expected. It is recommended to:
The customer will have to decide if they should do this occasionally or leave the Severe Interference Mitigation feature disabled.
