Q:
What does default.cfg_msync_glbl mean?
The Configuration file changes whenever one of the following things happen:
a. Write-mem execution on CLI or web UI done on controller. b. If controller is local, a global configuration change in master followed by write-mem on master, This could be either partial or full sync. c. An internal write-mem (This happen rarely and mostly used with wizards). For any of the changes listed above, a backup will be done to the existing configuration file (default.cfg) before the change.
The name of the backup file will be in the following format default.cfg_<operation>_<date> (eg. default.cfg_msync_partial_2013-08-13_13-58-52) .
The operation could be "writemem", "msync_glbl", "msync_partial", "wmem_internal" corresponding the type of change as listed above.
