Q:
Forcing Firmware Upgrade on Aruba central (group level)
Central now allows you to run a firmware compliance check and force firmware upgrade for devices in a group. To force a specific firmware version for all AP devices or Switches in a group, complete the following steps:
1. From the app selector, click the Maintenance app.
2. Click Firmware.
3. Verify the firmware upgrade status for the device.
4. Click the settings icon at the top right corner. The Firmware Compliance Setting window opens.
5. Select the devices and the firmware versions for upgrade.
6. Select Auto Reboot if you want Central to automatically reboot the device after a successful device upgrade.
7. Click Save. Central initiates a firmware upgrade operation only for the devices that support the selected firmware version. If any of selected devices do not support the firmware version selected for the upgrade, a list of unsupported devices is displayed.
