Problem:
Will IAPs configured with static IP address switch to get IP address from DHCP?
The answer is 'Yes'. As per our requirement we can either have Instant APs assigned with static IP address or configure them to get IP address from DHCP server. However if these APs are configured with "internet failover" and "preemption" enabled in their uplink configuration then the APs would switch from static assignment to DHCP assignment and try to get IP address from DHCP server.
Let us see with an example of how this option impacts in a real time scenario:
1. Have an Instant AP configured with static IP address.
ArubaOS (MODEL: 335), Version 6.5.4.5 Website: http://www.arubanetworks.com (c) Copyright 2018 Hewlett Packard Enterprise Development LP. Compiled on 2018-02-10 at 14:39:17 UTC (build 63641) by p4build FIPS Mode :disabled AP uptime is 15 weeks 3 hours 18 minutes 5 seconds Reboot Time and Cause: AP rebooted due to loss power ======================================================================= Aruba# show ap-env ---------> Static parameters configured Antenna Type:Internal Need USB field:Yes name:Aruba ipaddr:10.2.16.10 netmask:255.255.0.0 gatewayip:10.2.0.254 dnsip:10.2.0.156 Wired Interface ---------------- mac ip gw-ip gw-mac status pkts macs gw-macs dot1q-pkts vlans --- -- ----- ------ ------ ---- ---- ------- ---------- ----- a8:bd:27:c5:c9:26 10.2.8.22 10.2.0.254 c0:67:af:93:89:41 enable 57382051 258 1 0 0 Master IP Address :10.2.16.2 IP Address :10.2.8.22 Netmask :255.255.0.0 Gateway :10.2.0.254 =======================================================================
Aruba# show log system Sep 13 00:22:44 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:23:47 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:24:03 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| Send awc hang detection. Sep 13 00:24:03 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| Recv awc hang reply. Sep 13 00:24:06 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:24:39 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:29:05 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| Send awc hang detection. Sep 13 00:29:05 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| Recv awc hang reply. Sep 13 00:29:08 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:29:41 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:30:44 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| arping ongoing for central rollback Sep 13 00:31:24 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| dhcp probe sucessfully for cloud recovery Sep 13 00:31:26 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| cloud failure trigger staticip to DHCP switch. Sep 13 00:31:26 cli[2921]: <341185> <WARN> |AP Aruba@10.2.16.10 cli| Retrieving ip address from br0, ip 10.2.8.22, mask 255.255.0.0. Sep 13 00:31:26 cli[2921]: <341274> <WARN> |AP Aruba@10.2.16.10 cli| Update election ip from br0, election ip 10.2.8.22/255.255.0.0. Sep 13 00:31:26 cli[2921]: <341004> <WARN> |AP Aruba@10.2.16.10 cli| build_my_ip_address:setting this as new IP address for swarm =======================================================================
=========================================== Aruba# show uplink config Uplink preemption :enable Uplink preemption interval :600 Uplink enforce :none Ethernet uplink eth0 :DHCP Internet failover :enable Max allowed test packet loss :10 Secs between test packets :30 VPN failover timeout (secs) :180 Internet check timeout (secs) :10 ===========================================
This change from static to DHCP is expected when those two knobs are enabled but this would cause a network down scenario when we are managing Instant APs with Static IP address. To overcome this situation either we need to have IP address assigned through DHCP for APs or disable "internet failover" and "preemption" from the uplink configuration.
Aruba# show uplink config Uplink preemption :disable Uplink preemption interval :600 Uplink enforce :none Ethernet uplink eth0 :DHCP Internet failover :disable Max allowed test packet loss :10 Secs between test packets :30 VPN failover timeout (secs) :180 Internet check timeout (secs) :10
