303h - Is there iAP and AP ?
  • 1.  303h - Is there iAP and AP ?
    Posted Jul 26, 2019 05:22 AM
    I'm looking for a pair of 303h for my own lab.
    I can't find the reference IAP 303h I only find AP 303h.
    Does Aruba still diferentiate IAP and AP?
    Thank you!
  • 2.  RE: 303h - Is there iAP and AP ?
    MVP EXPERT
    Posted Jul 26, 2019 05:39 AM
    The 303H is a Unified AP, therefore there is no longer separate IAP/AP versions. The single model will do both.
    https://blogs.arubanetworks.com/solutions/aruba-unified-ap-platform/
  • 3.  RE: 303h - Is there iAP and AP ?
    Posted Jul 26, 2019 05:43 AM
     Thank you!
    Regarding the 303HR, what does the R stand for?
  • 4.  RE: 303h - Is there iAP and AP ?
    MVP EXPERT
    Posted Jul 26, 2019 05:44 AM
  • 5.  RE: 303h - Is there iAP and AP ?
    Posted Jul 26, 2019 05:48 AM
    So basically the difference is it comes with the stand?
  • 6.  RE: 303h - Is there iAP and AP ?
    MVP EXPERT
    Posted Jul 26, 2019 05:52 AM
    Yep and it is already attached.
  • 7.  RE: 303h - Is there iAP and AP ?
    Posted Jul 26, 2019 06:02 AM
    Thank you so much!
  • 8.  RE: 303h - Is there iAP and AP ?
    Posted Jul 26, 2019 04:37 PM
    AP-303HR has an assembled and attached stand, as well as a power adapter and power cord in the box.
