Re: 40Mhz channels not working
yep the product (108/109) itself is only 2X2 .. that's y i wrote that it might be something in your macbook .... very wired..
You sure that u dont got iAP114 or iAP115 ????
Can u look on the unit itself? (it got more than 1 eth port? = RAP / it got leds under aruba logo? = AP114/115)
This is RAP 108/109:
This is iAP114-115:
Occasional Contributor I
Yes I'm 100% sure it's a RAP-109. 2 ethernet ports + USB on the side and it came with a nifty desktop stand.
Cheers,
Steven
