Aruba 275 Series AP went down and not Joining Controller
  • 1.  Aruba 275 Series AP went down and not Joining Controller
    Posted Sep 27, 2018 09:21 AM
    Dear Gurus ,
    I need your help regarding one issue whcih we are facing in our network . We have deployed Aruba 275 Series AP, in our infra , 10 of Our outdoor AP, went down instantly . We have recovered 7 AP,s but 3 AP,s are still able to join the Controller .Could you please suggest what could be the issue for this problem and how we can start troubleshooting that ( we have checked they are in the correct vlan and port shut / no shut is also done ).
    Thanks and Regards ,
    Muddy
  • 2.  RE: Aruba 275 Series AP went down and not Joining Controller
    Posted Sep 27, 2018 09:23 AM
    We don't have enough information to understand what could be wrong.  Was there an infrastructure event?
  • 3.  RE: Aruba 275 Series AP went down and not Joining Controller
    Posted Sep 27, 2018 10:27 AM
    Hi Joseph ,
    The switch got restarted because of power failure and than AP,s went down .
  • 4.  RE: Aruba 275 Series AP went down and not Joining Controller
    Posted Sep 27, 2018 10:28 AM
    The issue is this that i also dont have USB console cable which i can use for checking the logs in AP.
  • 5.  RE: Aruba 275 Series AP went down and not Joining Controller
    Posted Sep 27, 2018 10:41 AM
    What discovery method do the access points use to find the controller?
    Are you using high powered POE to power those access points?
    Are you using mesh?
