Hey guys,
so i try a lof of things and of course this message from google is annoying, that the website from my IAP is not secure.
And now i have also no access from my chrome and i need to use firebox.
Anyway.
For different future projects, also with an external captive portal, i would solve the major issue before.
installing a cert on the aruba.
- So i created certs with openssl
- I upload one of the certs in my IAP , certtyp: CA, it worked
- I tried to upload the same one as certtyp: web, it got an error message: cert_upload_convert_cert_error_txt
- Also for other types, it is not working. No clue why.
- Then i found this, I followed the steps to convert the crt and key files to pem , same issues.
- Currently is uploaded as CA, but i wanted for my web login. And later i need to do the same (i guess) for captive portal. There i have also one issue which is not clear for me (another topic).
I am just using IAPs without Clearpass or any other AddOns. And Aruba switches (but this should not be a reason for this).
So short and sweet:
Any ideas on how I can make an SSL cert for web access so it works smoothly?
thanks in advance
