Highlighted
Re: Aruba ap105 firmware
@bg wrote:
before you try, just upgrade the ebay-IAP to 4.2.4.2 and then it will fetch 4.2.4.3 from the existing cluster .
https://dl.dropboxusercontent.com/u/67416983/ArubaOS_InstantOS_Guides/Aruba_Instant_OS__4.x.__Early_Deployment_Beta/Release%206.4.4.8-4.2.4.2/ArubaInstant_Orion_6.4.4.8-4.2.4.2_56164
I think that everyone should be highly skeptical about receiving software from unofficial sources.  Please use Instant Software from here instead:
http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=21997
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Occasional Contributor I
Yep, thank you both very much. I'll see about returning it.
