Re: Central and IAP
Hi Gordon - sorry that this is taking so long to resolve. Thank you for your patience. One last request....can you send us the screenshot of your user profile info. This will have the email address and the subscriber ID info. It should look similar to this....
Super Contributor I
Re: Central and IAP
Hello Srinip,
As requested the information:-
gordon@nexwavetelecoms.com
100000547
Normal Guy
Occasional Contributor I
Re: Central and IAP
Hi Gordan,
I think I have identified the issue here. Looks like you tried to sign up multiple times with different email addresses and hence we ignored this one as a duplicate request.
I have requested TAC to follow up on this particular account and get this going for you. Once again apologies for the inconvenience and thank you for bearing with us.
Srini
Super Contributor I
Re: Central and IAP
Can I ask you if my account issue will contribute to the lengthly time for the IAP to "find" the Central server?
Normal Guy
Re: Central and IAP
In a way yes. If the IAP does not know which user account to check into, it will never be able to contact Central.
Super Contributor I
Re: Central and IAP
Since the account is unique for every email account why does it needs to take that long to get it on Central. There must be a reason for that right?
Normal Guy
