Thanks, this is the configuration
version 8.5.0.0-8.5.0
virtual-controller-country IN
virtual-controller-key bef90f4a019ababd6a049cd3940e3ee50b072f661d303cf858
name Z-AP-Pantry
terminal-access
clock timezone none 00 00
rf-band all
allow-new-aps
allowed-ap 40:e3:d6:cc:1f:76
allowed-ap ac:a3:1e:c5:8c:dc
allowed-ap 80:8d:b7:c4:41:06
allowed-ap 00:4e:35:c0:f3:50
allowed-ap 7c:57:3c:ca:9e:6c
allowed-ap 7c:57:3c:ca:95:74
allowed-ap 7c:57:3c:ca:af:9a
arm
wide-bands 5ghz
80mhz-support
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware
scanning
client-match
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin xxxxx
wlan access-rule default_wired_port_profile
index 0
rule any any match any any any permit
wlan access-rule wired-SetMeUp
index 1
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule ZWiFi
index 2
wlan ssid-profile ZWiFi
enable
index 0
type employee
essid ZWiFi
wpa-passphrase xxxxxxx
opmode wpa2-psk-aes
max-authentication-failures 0
rf-band all
captive-portal disable
dtim-period 1
broadcast-filter arp
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
dot11r
dot11k
dot11v
auth-survivability cache-time-out 24
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
infrastructure-detection-level high
client-detection-level high
infrastructure-protection-level high
client-protection-level custom
protect-valid-sta
wired-port-profile wired-SetMeUp
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-SetMeUp
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
enable
multi-swarm
airgroupservice airplay
enable
description AirPlay
airgroupservice airprint
enable
description AirPrint
airgroupservice "DLNA Media"
enable
airgroupservice googlecast
enable
airgroupservice "DLNA Print"
enable
