Default login for 303H admin/admin incorrect
This thread has been viewed 50 times
  • 1.  Default login for 303H admin/admin incorrect
    Posted Jul 19, 2019 04:49 PM
    Hi Guys,
    I've gotten hold of 2 303H APs for testing, I;ve gotten the ap's an ip address and woul dlike to login using login admin/admin.
    this however does not seem to work, the aps are new out of the box and there is no controller/dhcp options/dns-entry for provisioning in the network.
    Am I missing something?
    I've reset them about 2 times now.
    kind regards,
    Michael.
  • 2.  RE: Default login for 303H admin/admin incorrect
    Posted Jul 19, 2019 05:03 PM
    Hi Guys,
    Just found out the default login is admin/Serial.
    Thanks!
    Kind regards,
    Michael
  • 3.  RE: Default login for 303H admin/admin incorrect
    Posted Apr 21, 2021 02:53 PM
    I just took few news ones out of the box today, the username/password combo was admin/admin.  They were all the same.  I was looking and saw your post, I had forgotten the default.  I guess I don't configure these enough.
    Douglas Holmes
  • 4.  RE: Default login for 303H admin/admin incorrect
    Posted Apr 26, 2021 07:56 AM
    Older firmware (from my memory 8.4 and below) user admin/admin. All newer firmware user admin and the serial numbers of one of the APs in a cluster as the default and will ask you to change it on first log in.
    If APs have been sitting in a box for a long time, they may still user admin/admin for that reason.
  • 5.  RE: Default login for 303H admin/admin incorrect
    Posted Apr 26, 2021 08:15 AM
    Thanks.  It was a newly purchased 303h.  I have seen the serial number used on some newer AP's, but never the 303h.  Thanks for the input.
    Douglas Holmes
