Occasional Contributor I
Re: IAP-105 with Cisco Catalyst 3560 - NO DHCP
Sure enough I just swapped the Cisco ESX switch with a Netgear GS724TP and now all clients are connecting.  There must be something on the Cisco switches that causes broadast messages like DHCP to choke.
Any ideas?
I also tried an HP 2520G POE switch and I have good results.
This may have something to do with it.  The cisco switch port limiting the amount of DHCP from an IAP mac address.
https://supportforums.cisco.com/thread/2121079
Trusted Contributor I
well it is not limiting the ammount of DHCP, it limits the number of MAC adresses allowed on a port (port security) to prevent people from connecting a switch or such. for a port on which you connect an AP you should never configure port security. certainly not with a low number like 3.
